Infrasonic subwoofer
gatemplin
gatemplin Posts: 1,595
Check out this bad boy, a friggen rotary subwoofer.
http://home.comcast.net/~thomasw_2/RMAF2005.html
This thing goes down to 1 Hz. Rumour has it that it has killed 3 people.
More here:
http://www.eminent-tech.com/RWbrochure.htm
Oh yeah it costs only 13k.
Graham
Post edited by gatemplin on
    VR3 Posts: 29,427
    edited September 2005
    I heard about that on S&V a while back...
    The general consesus there was BS Flags..
  • Schris22
    Schris22 Posts: 983
    did they stick their head in the propeller?
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • gatemplin
    In other words, "the general consensus from people who havent heard it and dont know how it works". :p
    The pics were taken by someone who's audio opinion I highly trust, who had a demo by the guy who invented the sub and explained to him how it works.
    "Bruce ran test tones from 40Hz down to 2Hz. The drywall in the room was flexing as the room pressurized. His intended audience is ultra $$$ HT where it's intended to augment the lower octaves below where your normal sub dies..."
    Graham
  • michael_w
    michael_w Posts: 2,813
    I could see something like that really hurting people if it does actually hork out that kind of output so low. My guess is that since the average person with good hearing can only hear to 20Hz the fact that this produces sound you can't even hear you won't know you are melting your ears until you start to feel pain and at that point you have already done damage.
    To me it just looks like a fancy 1/2 hp electric motor with a fireplace fan attached to the front :D I think I'd enjoy audio more without one of those and having the privilege of being able to control my bowl movements ;)
  • gatemplin
    edited October 2005
    Well because of this subs output and the Fletcher-Munson curve, you may be able to "hear" quite a bit lower than 20 Hz.
    Here is another quote from Thomas, the guy that runs "the Cult":
    "Below 10Hz the drywall was visibly flexing, and his assistants were leaning on all the doors, otherwise they were rattling in their frames."
    Graham
  • gatemplin
    edited October 2005
    Here is a video thingy, look at how the blades pivot like helicoptor rotors.
    Graham
  • beardog03
    beardog03 Posts: 5,550
    edited October 2005
    nice fan..!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • eugene65
    eugene65 Posts: 29
    edited October 2005
    I hooked up my clothes dryer with some monster extreme to two 500 watt monoblocks, sounds awesome. Selling for 12k, a 1k savings for you guys, just because I'm a nice club member. :) My next version will totally knock all your walls down, its a wrecking ball version. Still in the lab on that project....
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2005
    I bet it does move some air, which is what producing sound waves is all about.
    Weird.
  • Emlyn
    Emlyn Posts: 4,708
    edited October 2005
    Beware of the 7Hz soundwaves!! :eek:
    Brown Noise
    Interesting infinite baffle system. Seems to use ideas obtained from helicopter rotor studies. I wonder if the hotel they set up in knew they'd remove the door between two rooms, build the enclosure for the driver, then run tests down to 1Hz.
  • beardog03
    edited October 2005
    I wonder if my SVS PC-Ultra will go that low..?
    I would like to try that on the other unsuspecting members of the house..!!!
    I know it`s mean, but hey three females...every stinkin month..!!???
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • michael_w
    edited October 2005
    You might be able to hit around 10-12Hz in room with the ultra. Just guessing by reading the specs but if it's placed correctly...
  • beardog03
    edited October 2005
    enuff for serious stainage, but no doodoo.... :eek:
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • brendy
    brendy Posts: 7
    edited October 2005
    As PT Barnum said " there is a sucker born every minute "
