Speaker Wire?
rbarbera75
Whats the best speaker wire out there to use. A while back I bought some Rokford Fosgate Riot Gamma speaker wire but I am just wondering if regular twisted speaker wire will sound just as good or if there is even something better out there.
Post edited by rbarbera75 on
when i buy all new wire for my truck, it will all be from www.knukonceptz.com
unless you are running a very high end sQ vehicle...I doubt you will be able to tell the difference. Get the good stuff if you can find it cheap...other wise... get what you can find.
Whats the best speaker wire out there? Any of them. As long as it reaches from amp to speaker theyre pretty much the same.
There will be differences in build quality and ability to stand up to the elements but from a performance standpoint, theres really not much difference from $4/ft speaker wire and $.18/ft lamp cord.polkaudio sound quality competitor since 2005
i choose speaker wire based upon how easy it is to work with... radio shack's is harder than titanium to bend, stinger's is very easy to curl and strip and work with...It's not good, very fundamentally simply not good. - geolemon
i like to get the twisted knukonceptz stuff. Pretty damn cheap and will help eliminate noise because of the way its designed. Theres a bunch of great wire out there though. The only speaker wire ill stay away from is monster...the insulation is total crap
