tricks to manage rattling glass pane windows
BIZILL
BIZILL Posts: 5,432
just got my new svs and the basswaves are kicking my windows' butts. what tricks do you all have to combat this? dynamat is NOT an option........for the smart aleck type. please help me!!!!! :eek: :mad: :confused:
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360
WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.php
bobman1235 wrote:
I have no facts to back that up, but I never let facts get in the way of my arguments.
Post edited by BIZILL on
  • Frank Z
    Frank Z Posts: 5,860
    edited September 2005
    What kind of windows? Have you tried adding some small pieces of weather stripping to tighten up the windows in their tracks?
  • danger boy
    danger boy Posts: 15,722
    Bill, where did you place the sub? ratteling windows is a freebie courtesy of SVS. :D
    corner placement of the sub is preferred. willl yield the most bass output. proper speaker level calibration is important. but most people run their subs a little hot too. I know you just got your sub.. so it takes some time to tweak it as time goes on.
    enjoy it, al
    PolkFest 2012, who's going>?
  • BIZILL
    BIZILL Posts: 5,432
    cheap **** thin, single pane windows. somehow i think i'd have to remove the windows in order to smush some stripping in there. hmmmmmmmm, perhaps some silicone???
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • beardog03
    beardog03 Posts: 5,550
    or a thin strip of duct tape along the edges...
    silicone might help...definately can`t hurt
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • BIZILL
    BIZILL Posts: 5,432
    enjoy it, al
    definately in the corner. also the corner right next to the worst vibrating/clattering window! there is so much pressure in the room that placement will not stop the rattling. i have yet to calibrate, as i have not had time. but even calibrated levels will yield the same prob with the windows. ah dang.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • BIZILL
    BIZILL Posts: 5,432
    thought about that too, but came to the conclusion that it would detract from the beauty of the home. but i think it would work. maybe i can cover the duct tape with some lace and lillies or somethin'......... :rolleyes:
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • BIZILL
    BIZILL Posts: 5,432
    or did you mean in the tracts so as to remain unseen? maybe just enough to stop the clattering effect..........
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • danger boy
    ummm. you might need to recaulk them windows.
  • BIZILL
    BIZILL Posts: 5,432
    it's all in aluminum tracts. i'll try wedging various materials in the cracks of the stationary pane. the clatter actually forces me to keep the volume lower than i'd like.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • beardog03
    either way..
    my first thought was on the window itself, but because you will see it... :confused:
    how about glueing a 1/2" strip of cork around the edge of the window ?
    or just the top and bottom..?
    stuffing cotton, or small felt strips between the window and widow pane would work if you get it in with a putty knife..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • PolknPepsi
    PolknPepsi Posts: 781
    Silicone comes in clear and many colors now days, I dont think it can be painted. We have a large corner cabinet that rattled china and the black foam shelf liner did the trick. What helped the most and prevented the walls and floor from shaking was isolating the sub, that made the biggest difference.
    My cylinder is on 3 spikes then on a round concrete slab from home depot, then on top of 10 squash balls hot melt glued to the underside. Looks very nice after spray painting the concrete and squash balls flat black.
    I think there is a pic on a photo disc but I'm not sure how to get it here :confused:
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • unc2701
    unc2701 Posts: 3,587
    Caulk... lots of caulk.
    Backburner:Krell KAV-300i
  • gatemplin
    gatemplin Posts: 1,595
    I have similar windows, I shove tooth picks in between the tracks and window to keep them from moving. If I want to open the window, I just remove the picks and them replace them after.
    Graham
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Turn it down ________!
  • goingganzo
    goingganzo Posts: 2,793
    i have similar problems with rattleing but it is not the windows it is the house that rattles. and what you can try is caucking around the area where the glass hits the fraim and then nailing the windows shut
  • Polkersince85
    Polkersince85 Posts: 2,883
    The windows are being pressurized from the inside of the house. Maybe try caulking the outside frames as you apply slight pressure inward.
  • BIZILL
    BIZILL Posts: 5,432
    i knew someone would suggest this...........no way, my bro. :D
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • BIZILL
    BIZILL Posts: 5,432
    goingganzo wrote:
    ..... nailing the windows shut
    just made me think.......i've got aluminum tracks. perhaps tiny sheet metal screws to hold the window tight!! self-tapping screws! we may have a winner! and the color of the galvanized screws would blend semi-closely to the aluminum frame. :rolleyes: thanks, ya'll.
    .........still in the market if you all still have suggestions to make.....
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • BIZILL
    BIZILL Posts: 5,432
    beardog03 wrote:
    either way..
    this was my very first thought at the time (duct tape) the rattling occured. placing a few strips of duct tape to the glass itself. but after closer examination, the clattering is from the glass' frame vibrating against the frame attached to the wall.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • PolknPepsi
    edited October 2005
    Have Rhino Liner (a truck bed liner company) come in and spray the entire inside of the house, it should soundproof everything. :D;)
  • BIZILL
    BIZILL Posts: 5,432
    edited October 2005
    the svs's finish on my speaker reminds me of rhino lining. it is actually quite nice looking. if i ever get around to buying a '72 blazer, i'd like to rhino line the entire cab area. seen it done.......very nice.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
    VR3 Posts: 29,442
    edited October 2005
    expanding foam
  • scottnbnj
    scottnbnj Posts: 709
    edited October 2005
    how often would you like to open them? was there weather stripping in there originally that's worn? if yes, maybe remove and replace. if no, try to add some. home improvement stores should have different types and thicknesses. if you can find it, the furry type would probably be the most durable.
    if you don't see anything there that looks like it will hold up to opening and closing, maybe the soft side from a roll of velcro would fit.
  • PolknPepsi
    edited October 2005
    expanding foam
    That expanding foam is sure some crazy stuff to play with.
  • BIZILL
    BIZILL Posts: 5,432
    edited October 2005
    the window pane is a stationary one. i just want to go the least obtrusive route, visually speaking. didn't have time to tinker with it this weekend. i'll get on it soon enough. thanks all.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • scottnbnj
    edited October 2005
    wood shims then. find them in the millwork section of home improvements store. tap them in with a hammer, trim with a razor/utility knife.
