Blown voice coils
hello all
hi I am thinking of buying some vintage speakers of ebay but the bass unit is large and oval so I dont think spares are available but however if i blow a voice coil could it be fixed???? And what if the rubber surround goes??
(8 days to go)
(8 days to go)
ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
Post edited by ward91 on
My guess is you would be out of luck. The thing to do is to look everywhere on the internet. If the speaker has a following there is a good chance someone out there may have a solution for you. Can you mention what it is?
Its a TDL studio 4 (on the right)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5812570892&indexURL=2&photoDisplayType=2#ebayphotohosting
http://digilander.libero.it/piani/cataloghi_tdl/tdl_electronics_reference.jpgELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
hmmm...probably not a good idea, imho....see the shape of those drums in the picture? think of the shape of the sound waves from them...now picture the speakers waves....i don't know nuttin though...could be a lot of hooey
the ovel bass driver was to reduce cabinate sizeELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
sounds like a design/engineering compromise.....they're are smaller normal drivers that could be set up in pairs, for exmpl
huh..ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
The first step would be to try here and see if the manufacturer is still in business and if they offer replacement parts.
TDL Electronics (Audacity Audio Limited)
PO Box 98
High Wycombe
Buckinghamshire
HP10 9SH
Tel: +44 (0) 1628 850111
Fax: +44 (0) 1628 850130Vinyl, the final frontier...
the manufactoror went out in the mid 90's but i will still try the phone number tummorow as it is 9:00pm in the uk.
sent emails to the folowing
http://www.aos-lautsprecher.de/
(reply said that a guy down soulth could fix blown coils but no spare units)
https://secure.wilmslow-audio.co.uk/acatalog/Wilmslow_Audio_Repair_and_Upgrade_your_Loudspeakers_155.html
(wanted info as they had non on the studio 4)
http://www.lockwoodaudio.co.uk/
(ran out)
cheersELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
i tried the number and they are inactive i dont think i can buy these as the price will most likely go wp quite a bit more than i can really afford.
there is a guy that his expertise are with TDL so if they did break they could be fixedELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
