Transmission Line Subwoofer
unc2701
unc2701 Posts: 3,587
edited September 2005 in DIY, Mods & Tweaks
The woman was out of town, so a friend of mine & i decided to throw together a sub subwoofer with the lowest possible WAF, cost and -3db limit. The cost and the ability to put it together stinking drunk were the true limits.
He had a spare Polk 10" DB series driver, and I just picked up the crown amp from hoosier, and there was plenty of scrap plywood in the garage from another project. For a crossover, I used a variable psuedo active FMOD... mid 50's to 60's seemed to blend well with the LSi 9's, but even going up to 89 didn't get too boomy.
So, 2 hours and $30 later (that includes the beer) we had this:
Backburner:Krell KAV-300i
Post edited by unc2701 on
  • BrentMcGhee
    BrentMcGhee Posts: 548
  • hoosier21
    hoosier21 Posts: 4,424
    So how did it sound?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • unc2701
    The sub fires upwards in to an 8' X 12" diameter concrete form tube. The tube could stand to be a hair shorter to match the Fs of the driver, but for our purposes it didn't matter that much. The idea is that the tube is 1/4 the Fs for the driver, so the backwave comes out of the tube in phase with the bottom end, extending your response. You also get some of the tight punchiness of a sealed enclosure since the length allows for a good bit of pressure to build up at the driver end of the tube. The only real drawback is that it's one ugly ****. Oh, and if your driver's Fs is more like 20 hz, you need a 14 foot tube...
    How did it do? for a driver with a Fs of about 40 hz, it was hitting things that it never should have been able to reach- well into the mid 20's I'd say. We were too drunk to, say, run test tones, but it had no trouble digging all the way down to the lowest notes (we had to break out some Chemical brothers & Outkast go past the low E).
    So if you've got some free time it's a fun project to try out. Oh, and needless to say, the tube is going out with tomorrow's trash... (the woman didn't think it went with the rest of the decor...)
    VR3 Posts: 29,609
    I'm confused... how is this a transmission line?
    A transmission line is something like this...
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    Sid - I seen a T line sub that some of the guys were playing around with in Home Theater magazine about a year ago. It was something like 16 foot in length. They to, just wanted to see what it would sound like, from the article it was said that a T line sub is any cabinet design where the sub driver is mounted on one side of the tube...Wait a minute............
    O.k. googled the H.T magazine description...here it goes
    "Transmission Line: A (sub)woofer cabinet design where the driver is mounted at one end of a tube with the same diameter as the radiating area of the driver and a length of 1/4 wavelength of the 3dB down frequency. This "tube" may or may not be round and may be folded to decrease the size of the cabinet."
    scott
    not as large, but looks nice
    http://www.teresaudio.com/haven/subs/subs.html#cabinets
  • phoneisbusy
    phoneisbusy Posts: 867
    unc2701's is a straight transmission line, I believe yours is a folded style. If you want it more esthetically pleasing and you think the wife will not notice a slight bump in the wall you can try...
    http://www.t-linespeakers.org/projects/peter/index.html
    heh... ;)
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • unc2701
    Yep, it's just a straight T-line... you could fold it like that picture, but that'd take time, money and sobriety. I will admit that the sonotube was vibrating some, but I doubt that PVC would be much better. Since the pressure is distributed equally, the cardboard is plenty thick (it's like trying to crush an egg by squeezing it...)
    VR3 Posts: 29,609
    Gotcha :D
    Cool
  • tryrrthg
    tryrrthg Posts: 1,896
    Very cool project.
    For those that have never seen this link before. Here is Nelson Pass' El Pipo T-Line sub.
