SVS 20-39PCi
hexumjunkie
hexumjunkie Posts: 191
thinking about buying this will my H/K AVR 635 power it fine? work better than my 8 inch sony
Post edited by hexumjunkie on
  • faster100
    faster100 Posts: 6,124
    edited September 2005
    Its self powered, doesn't matter what receiver you use really
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • McLoki
    McLoki Posts: 5,231
    It is a self powered sub so you will not have any issues with power. It will destroy your sony. You will have to rewatch all the movies in your collection just to hear what you have been missing. (yes, even the bad movies) You will be astounded.
    You can also get a free "tune" to about 18hz if you just ask SVS for it. (if you are purchasing it for movies, I would get it - if it is for mainly music, I would not)
    Michael
  • danger boy
    danger boy Posts: 15,722
    I think it'll work a little bit better than your 8 inch Sony, yeah. no doubt about that. :p
    PolkFest 2012, who's going>?
  • Shizelbs
    Shizelbs Posts: 7,433
    It will swallow your Sony whole.
    VR3 Posts: 29,697
  • PolknPepsi
    PolknPepsi Posts: 781
    Any questions?............ :D
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • Tritonman
    Tritonman Posts: 159
    Hilarious!
  • hexumjunkie
    is this thing really as good as people say it is? i mean 650 is some money for a 24 year old college student
  • danger boy
    SVS makes a couple of other smaller less expensive subs.. but equally as good. check out their web page.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Yes.
  • hexumjunkie
    im dead set on this are the velo comparable?
  • AsSiMiLaTeD
    Velodyne makes good stuff, but I don't think it quite stands up to SVS dollar for dollar.
    You may want to check out HSU as well if you're considering other brands - it's more equivalent to SVS IMO
  • aaharvel
    aaharvel Posts: 4,489
    The Sony sub would own the SVS in a 1 on 1 comparo.
    OWN BABY!!! :cool:
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • hexumjunkie
    i want sub to shake the foundation when something blows up.....i also have older hardwood floors will this matter?
  • AsSiMiLaTeD
    With hardwood floors, you'll likely have to put something under the sub to keep it from moving around. If you set it directly on the floor and crank it, that sub will move around on you. While it's cool the first time you see it, not something you want on a regular basis
  • okiepolkie
    okiepolkie Posts: 2,258
    Whatever sub you end up with, if you want to cut down on some(not all) of the wood-floor resonances, get a slab of granite to put underneath so the air coming from the subwoofer goes to you and not the floor.
    Tschüss
    Zach
  • faster100
    I have hardwood under carpet.. i tried the slab and although it took some vibration out it also took some impact with it, My room is small and its a big svs.. i didn't drop a G to lesson impact.. suffice to say it works but i prefer full impact!! :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • okiepolkie
    I like the impact as well, I just hate rattles(or unwanted vibrations). Some old hardwood floors tend to have a few rattles because of some loose boards here and there.
    Tschüss
    Zach
    VR3 Posts: 29,697
    If you want to literally just shake things, SVS will do that better than ANYONE for the money. Period.
  • snakebitten
    snakebitten Posts: 94
    I bught my svs last week. (b-stock) I didnt have time to play with location or calibrate my system, but wow what a difference. And I got the lower model 20-39 pci.
    It is a bit on the large side though. But sounds good.
  • hexumjunkie
    man wish i could get one b-stock
  • danger boy
    patience is key to finding good b-stock subs
    the 20-39pci isn't small by any means. nice thing is it weighs just a fraction of what a box sub does. but it's bigger than most people think it's going to be. :D
  • McLoki
    McLoki Posts: 5,231
    How big is the room you are trying to fill? If it is a bed room or dorm room, the PB-10 will be more than enough for you (and they do have some b-stock). If it is a large room, you may want to stick with at least the 20-39. You can e-mail SVS and tell them the size of the room. (be sure to mention you have hard wood floors) also tell them what you are looking for in a sub and they will not steer you wrong....
    Michael
