please help newbie to install tweeter
ctfshjohn
ctfshjohn Posts: 8
edited September 2005 in Vintage Speakers
just inherited a pair of POLK AUDIO MONITOR RTA 11T TOWER
want to put a new tweeter in will this be tricky?
any help is appreciated.
can i use a POLK SDA/MONITOR 10 TWEETER that is not silver coil or can i only use a Polk Audio Silver Coil SL-2000 Tweeter?
thank you for your input
Post edited by ctfshjohn on
  • ND13
    ND13 Posts: 7,601
    Call Polk and order the silk replacements. You can get them for $48 ea. shipped. You'll be very, very happy you did. Replace both.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • ctfshjohn
    ctfshjohn Posts: 8
    thank you for the recommendation
    F1nut Posts: 52,008
    I'll echo ND13's comments. Replace both and enjoy your new speakers. The RD0194-1 tweeter is a vast improvement over the old SL2000. Be sure to note which wire goes where.
  • loh_kg
    loh_kg Posts: 13
    Hi
    The RD0194-1 is it better than SL3000 tweeter.
    F1nut Posts: 52,008
    loh_kg wrote:
    Hi
    No, that is wrong. The RD0194-1 replaces the SL2000, while the RD0198-1 replaces the SL3000.
