please help newbie to install tweeter
ctfshjohn
just inherited a pair of POLK AUDIO MONITOR RTA 11T TOWER
want to put a new tweeter in will this be tricky?
any help is appreciated.
can i use a POLK SDA/MONITOR 10 TWEETER that is not silver coil or can i only use a Polk Audio Silver Coil SL-2000 Tweeter?
thank you for your input
Post edited by ctfshjohn on
Call Polk and order the silk replacements. You can get them for $48 ea. shipped. You'll be very, very happy you did. Replace both."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
thank you for the recommendation
I'll echo ND13's comments. Replace both and enjoy your new speakers. The RD0194-1 tweeter is a vast improvement over the old SL2000. Be sure to note which wire goes where.Political Correctness'.........defined
President of Club Polk -
Hi
The RD0194-1 is it better than SL3000 tweeter.
Thanks -
loh_kg wrote:Hi
No, that is wrong. The RD0194-1 replaces the SL2000, while the RD0198-1 replaces the SL3000.Political Correctness'.........defined
