Sony SACD question?
dagame27
dagame27 Posts: 599
edited September 2005 in Electronics
Hey guys I have a sony ce595 SACD player. I noticed that with redbook cd's, I was getting no sound out of my subwoofer. I have it hooked up with the mulitchannel analog outputs. I then hooked up the digital out as well and now I get a much livelier sound including my sub. Does this have something to do with the encoding in my player? Can I not get a sub signal out of the analog outputs with redbook cd's? Thanks
Chris
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
  • BrentMcGhee
    BrentMcGhee Posts: 548
    On the player there should be the multi-channel outputs as well as stereo line level outputs and the digital output. The multichannel outputs will only output what is on the cd. So where as a sacd has speceific information for all channels a standard redbook cd does not, it only has 2 channels right and left. That is why when you use the multi outs on a redbook you dont get anything out of your sub. To get sub out of your redbook you have to use either the stereo linelevel outs or the digital out to the receiver.
  • dagame27
    dagame27 Posts: 599
    thanks Brent, that is what I suspected
