Which rear surround speaker?
Which is a better rear surround speaker for my HT setup? I am thinking about switching out my RTi28's for FX300i's.
My current set up:
Front: RTi100 or RT800i (not sure which one to use yet)
Center: CS400i
Rear: RT55i
Sub: PSW450
Also how much should I ask for the RTi28's and how much should I pay for FX300i's?
Thanks.
My current set up:
Center: CS400i
Rear: RT55i
Sub: PSW450
Thanks.
It is your choice what you like for surrounds. I have used both a direct radiating RT25, RT55 and dipole/bipole models FX300 and RT/FX. I like the direct models for multi channel music (SACD/DVD-A) and the dipoles for movies. The dipole models work best for me on the sides when I use my HT setup in a 7.1 mode with the unipole models for the rears.
28s & 300s? Both models bring around 125-150 a pair.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
bipoles imo. the f/x 300's in Bipole mode. Provides a perfect blend between diffuse and direct sound.
