receiver choice
moraks
moraks Posts: 49
edited September 2005 in Speakers
i am in the process of setting up a media room with rti12, csi5,fxi5 and the psw 505, i am trying to decide on a receiver, i am down to yamaha rxv 2500 or denon 3805. please advice if this are good choices or can I get a better bang for my buck with something else. my wife has me on a budget :)
Post edited by moraks on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Welcome to the forum!!
    Both receivers are great multichannel processors, but neither will drive RTi12s very well. The bass drivers in that big of a speaker deserve power from a separate amplifier. 200 wpc for the 12s would be just right, then the sub would be your next weakest link. Polk subs aren't anything to write home about. SVS, HSU, Outlaw and Rocket all make subs that will keep up with the rest of your gear.
  • moraks
    moraks Posts: 49
    thanks, Dennis,
    after reading the thread about upgrading from rti8 to 12, i might go down to the rti8 and also select a sub from another vendor do you have a recommendation?
  • Dennis Gardner
    Any of the SVS box models would blow you away! They are more $$$ to start with but if movies are going to be the main event in your media room, you gotta have a sub that will keep up with those action movie soundtracks. They are really punishing on a sub that doesn't reach low and loud enough to fill your room.
    SVS
    HSU Subwoofers
    Outlaw Audio LFM-1 or LFM-2
    Good luck in your search, it is half the fun!!
  • aaharvel
    aaharvel Posts: 4,489
    dennis those are great sub recs.
    I also would take the Denon over the Yamaha. Don't trust Yamaha's wattage specs.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • moraks
    moraks Posts: 49
    thanks Dennis, i need to catch some zzzzs, will research this tomorrow, i could use the funds saved from the rti12 for the sub
  • pearsall001
    pearsall001 Posts: 5,294
    Receiver : NAD T773 & never look back!
    SUB: SVS 25-31PLUS - the combo of the two are absolutely fantastic!
  • unc2701
    unc2701 Posts: 3,587
    Don't trust dennon wattage specs either... I'd say get the cheapest yammie w/ pre-outs, then get yourself a real power amp when you can afford it ('cause you'll need it sooner or later).
    Backburner:Krell KAV-300i
  • moraks
    moraks Posts: 49
    are you saying that I should use this combination with the Rti8 or with the Rti12
    thanks for the info :)
  • aaharvel
    good point. but imo Denon is a better product than Yamaha- and their wattage specs while not as accurate as say NAD, B&K, Marantz or H/K- are still much better than most.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • ninerbj
    ninerbj Posts: 870
    I have been using the Denon 3805 for about 6 months now in my HT room...I am VERY happy with it.
    "she had the body of Venus, with arms."
  • moraks
    moraks Posts: 49
    ninerbj,
    what kind of speakers are you using with the denon 3805
  • tdogroeder
    tdogroeder Posts: 53
    SVS
    HSU Subwoofers
    Dennis, I have a PSW303 sub, and It's not enough. I was thiking about going with HSU VTF MK2. I mainly use my system for movies, but do want the sub to sound nice for music. If I got this sub how much better would it be than my polk sub? I have considered the SVS PB10, and HSU STF-2 subs also.
    Yamaha RXV-757
    JM-Lab Focal Cobalt 816 S's, JM-LabFocal Cobalt CC 800 S, FXi3's, RT15's & PSW 303
  • Dennis Gardner
    The lowest level of either brand will play lower and louder than the 303. I would sell the Polk and buy the most sub I could afford and fit into my room. Musicality will abound in any of the choices from both brands.
    What size room and what speakers are you looking at using for your system?
  • moraks
    moraks Posts: 49
    Dennis,
    i am down to the SVS pb12-isd and the outlaw lfm1 as my choice, my set up with the rti8, csi5 and fxi5 is mostly for HT, what is your recommendation for the sub
  • Dennis Gardner
    Tossup.........................the performance is too close to call between these two. Choose the one that fits your decor best. The SVS does have different veneers and textures that are nice.
  • aaharvel
    Denon or Yamaha? Screw it. Just get yourself a Harman Kardon and relieve yourself of the misery of having to decide between runnerup and 5th place. =)
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Toxis
    Toxis Posts: 5,116
    runner up eh... I can tell you don't sell HK for a living... you might change your tune. ;)
  • aaharvel
    yeah those damn bugs and half second delays can be a real pain in the **** can't they? :)
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • ninerbj
    ninerbj Posts: 870
    Moraks,
    HT has old Polk S10's, S4's, LSic (with and Outlaw m200 mono) and SVS 25-31 PCi
    VR3 Posts: 29,432
    Do yourself and favor and don't buy Yamaha, HK, Denon, Sony, JVC, Panasonic, Pioneer...etc
    And buy something from NAD and Outlaw. Be different! Don't go mainstream! ;)
  • kingtut
    kingtut Posts: 813
    How about the new Outlaw receiver. The last one had the true wattage specs and had rave reviews. The new Outlaw should be just as good, probably a substantial improvement.
  • Eman
    Eman Posts: 60
    I suggest Denon or Harman Kardon and I have an HK myself and am planing on getting a second one. I recently have had clipping issues with many receivers except the high current HKs though I must admit I have not tried Denon. Customer service and tech support is just as good as Polk if not better and that is saying a lot. Their musical ability, pre outs for separates, as well as their multiple crossover/bass management (even for 5.1 analog in) are extremely useful in milking every ounce of sound from your speakers. So put them on your list - at the top.
