Vibrapods and points
emcclary
emcclary Posts: 29
Has anyone used these items in isolating their system? I am building a built in cabinet for my whole system and was thinking of using these on the receiver, dvd player and cd player. I know they sell the points to go with the pods but they arent for sale at the polk site yet. Any feedback would be appreciated.
HT Setup
Rec B&k AVR307 w/updated software and hardware
DVD Sony DVP S9000ES
VCR JVC SVHS HR-S3600U
CD Nakamichi MB3S
2 Monster HTS3600
Sony KF-60XBR800 LCD Proj
Mains Def Tech BP7004
CLR Def Tech 2500
Sides Def Tech UIW BPZ/A
Rears Def Tech BPVX
Sub Def Tech Supercube 1
Outdoor System
Rec Sony STR DE197 (2 Chan)
Cd Nakamichi MB3S CD (Yes I have two of them)
Speakers Paradigm Stylus 350's
Post edited by emcclary on
  • steveinaz
    steveinaz Posts: 19,545
    edited September 2005
    I've used vibrapods before under my cd player. Be careful as they can mess up some wood finishes. I don't know if the Vibrapod conepoints have this issue.
  • emcclary
    emcclary Posts: 29
    Yeah Ive read that but I will be putting sheet of cork under them to keep them off the wood finish. I am interested in trying the pod/conepoint combo
    HT Setup
    CD Nakamichi MB3S
    2 Monster HTS3600
    CLR Def Tech 2500
    Rears Def Tech BPVX
    Outdoor System
  • Conradicles
    Conradicles Posts: 6,340
    edited July 2009
    Bump, I want to hear what others think about these.
  • dragon1952
    dragon1952 Posts: 4,907
    edited July 2009
    I used them for years until just recently. I think it depends on how solid your rack is and what it is made of, and the weight of your components along with the quality of their stock feet. If your built in cabinet will be nice and solid, and not prone to vibration, that would help. Maybe you could even dampen it with something, like packing some nice thick insulation around it. I decided that my tube integrated was heavy enough (45-50lbs), and on a solid enough surface that it didn't need anything. My new CDP is almost 30 lbs and has very good stock feet, so I decided it didn't need them either. My old CDP was much lighter and I think it may have benefited from them though. But with some components they may soften the sonics a little bit. I think a firm, solid surface is better in some cases. Sometimes you just have to experiment and see how your components react to something like Vibrapods.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    I'd also like to hear what others have to say in regards to following online-instructions on what ones to choose from/etc and how they worked out for them.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
