ALLRIGHT!! Finally got a new PC!!!!
  • ND13
    ND13 Posts: 7,601
    edited September 2005
    It's all good, because I'm accustomed to not even 56k :o at home. And the cable is supposed to be twice as fast as the DSL I was looking into. :)
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    heiney9 Posts: 25,398
    You are going to have some fun when you get it all up and running. :D
  • ND13
    ND13 Posts: 7,601
    Yep, I have the system up and running, just not connected yet. Will be installing that after work tommorrow night, so about 27 hours to lift off.
    You are getting a good deal @ $30 a month with Insight. I use Insight and that offer came around *after* I got mine up and running. My intial offer was $19.95 for the 1st three months. Now I pay $44.95 a month and was none too happy when the $30 offer came out. I tried to switch but since I have no other choice in my area for cable.....they politely told me it was not possible to get that deal :mad:
    What modem are you using? I originally bought the one from Insight but could never get to intialize after the install guys left. It was a top line RCA DCM 425. I ended up getting the Motorola SB5100 which has worked out much better.
    Just curious
  • ND13
    ND13 Posts: 7,601
    Motorola, just don't have the number yet.
  • maggiefan
    maggiefan Posts: 223
    Someone mentioned that XP pro has the restore funtion, home has that too.
    Larry
    That was me....I guess I didn't realize that :). It definetly saved my a** and a lot of time and trouble!
  • Polk addict
    Polk addict Posts: 558
    Comcast speeds vary. It's a good thing it doesn't go lower than 2.0. But that's kind of pathetic considering most people in my area aren't even using Comcast. Otherwise the server itself is awesome.
    Chiranth
    hoosier21 wrote:
    Cobra + SDA's = dead amps laying all around.
  • Polk addict
    Nevermind. I changed my mind. I think Comcast is cool :cool:, but they took forever to activate our service :mad:. Tell me whatcha think of my non-sense. By the way, each different service usually has their own rules for new service. Comcast, so far will give you a month free, but you have to wait about two weeks of that time. that's the best I've heard them do. :mad:
    Chiranth
  • michael_w
    michael_w Posts: 2,813
    I myself havn't really noticed a whole lot of difference between xp pro on my computer and xp home on the family computer other than being able to setup a remote desktop connection. My computer is a little faster despite the specs that show it is much slower and a little more stable but I don't know if that has anything do do with win xp. I don't really do much networking or anything fancy but I went pro because it was free...
  • ND13
    ND13 Posts: 7,601
    Just curious
    Just got the modem and it's the Motorola SB5100. It was alot cheaper to buy it from Insight than to buy it from Wal Mart :confused: . Got it, nib, for $39, WM sells it for $59, unless it has gone down recently. Now to get the router, today, so i can get online tonight :) . It seems that the most suggested router is the Linksys, so I guess that I'll go that route.
  • nadams
    nadams Posts: 5,877
    XP home is fine for home users. XP pro adds some other networking options that Home doesn't have, such as joining a domain. Most home users don't have to worry about joining a domain!
    Also, another good speed test site is www.bandwidthplace.com/speedtest/
    Ludicrous gibs!
    So they are back to selling the Motorola again :) . When I signed up in January of this year my impression was I should have gotten the Motorola but they gave me the RCA instead also $39. So I spent $89 on the Motorola at BB. Anyway you look at it you are getting the better deal now, 9 months later. The RCA seems to have gotten good reviews but I never got it to work properly. The Motorola should be a very good unit.
  • ND13
    ND13 Posts: 7,601
    Okay, it's off to Wal Mart to pick up the router, then to the hacienda to do the install. Wish me luck :)
    Hopefully, everything will just fall together and I'll be back online in a couple of hours on the new home PC :D
    ND13 wrote:
    Okay, it's off to Wal Mart to pick up the router, then to the hacienda to do the install. Wish me luck :D
    Luck Wish.....get to it! :D
    SCompRacer Posts: 9,082
    Always remember, luck is where preparation meets opportunity. Blind luck is getting it to work without knowing how you did it. :D
    You don't have to install the cable companies software for that stuff to work either. All they need is the MAC address of the modem. Once you get up and running, change the password on the router. The default password will most likely be 'admin' on the Linksys.
    Noel.....are you receiving us yet??? :D:p . How's the install going? Over..Roger that..Out
  • ND13
    ND13 Posts: 7,601
    Online and it's freakin faster than the t1 line at work :D
  • ND13
    ND13 Posts: 7,601
    Haven't got the router yet, will get with you(Rich) tommorrow on the landline.
    I can't seem to sleep past 1PM these days so early afternoon is most likely.
    Njoy the bandwidth. :cool:
