Computer gurus ?
shack
I am getting a new ISP with DSL and wireless home networking. Obviously my desktop will be hardwired and my daughter's laptop is already wireless capable. I have a Dell laptop that is not wireless capable. The ISP will upgrade it for $60. Is this the best option or is there a better way to upgrade the laptop to go wireless? Oh...the ISP is TDS (who has my phone service) if it matters.
Thanks in advance.
Thanks in advance.
"Just because youre offended doesnt mean youre right." - Ricky Gervais
They are just adding a wireless NIC to a slot on the laptop. I think I paid about $60 for mine two years ago.
It is an 802.11g nic. Will any brand work?"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
shack wrote:It is an 802.11g nic. Will any brand work?
Yes... any brand will be ok.<|> -
Thanks for the info."Just because youre offended doesnt mean youre right." - Ricky Gervais
any brand will work....I've seen wireless nic cards for $15-$60...one very important thing: make sure you enable wireless security. Too many people leave their wireless networks wide open ( I can see at least three other available open wireless connections in my house, probably my neighbor's)....make sure the wireless nic card has the compatible security features as the router. I use WPA encryption on mineReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Yeah. Be sure to get a firewall!
It's almost neccessary. Most wireless routers have it built in. :cool: -
Mike682 wrote:. Too many people leave their wireless networks wide open ( I can see at least three other available open wireless connections in my house, probably my neighbor's)....
So that means you could log on to one of their networks then, right??"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
ND13 wrote:So that means you could log on to one of their networks then, right??
Yep, I can search available networks within my range, and if they are not secured, I could just jump on. When you secure your network, it becomes password protected so others can't jump on to your network.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
That's what i thought. I think I'll just go with a hard wired router, since I'm not gonna have more than 1 in the house anyway, and I really just want it for the firewall, cause several have suggested doing the router thing for just that reason alone."SOME PEOPLE CALL ME MAURICE,
ND13 wrote:That's what i thought. I think I'll just go with a hard wired router, since I'm not gonna have more than 1 in the house anyway, and I really just want it for the firewall, cause several have suggested doing the router thing for just that reason alone.
You can go with a combo router that is both wired and wireless just in case you ever want to add a wireless laptop or something in the future. You can disable the wireless part until you are ready to use it..
Here is mine:
http://www.linksys.com/servlet/Satellite?childpagename=US%2FLayout&packedargs=c%3DL_Product_C2%26cid%3D1115416825557&pagename=Linksys%2FCommon%2FVisitorWrapperReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
wireless nics don't need to cost 60 bucks.. plenty available with rebates for 20 -30 bucks.... I run a wireless laptop with wep incryption... just make your own code don't let windows enter one for ya... My is locked up so the cable guy and anyone else can't borrow my broadband.. plus if you don't share folders or hard drive partitions people cant get ON your computer anyways, just use your internet access.. Good luck,
Yes dual routers are great, I have a D-link, 3 ports and wirelessMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Mike682 wrote:You can go with a combo router that is both wired and wireless just in case you ever want to add a wireless laptop or something in the future. You can disable the wireless part until you are ready to use it..
Here is mine:
They have that one Wally world. How much should I expect to pay for one like that??"SOME PEOPLE CALL ME MAURICE,
I've seen it go for $39....Compusa has it for $49 after rebate..
http://www.compusa.com/products/product_info.asp?product_code=299891&pfp=cat3Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
I don't need the one with the Speedbooster, do I?"SOME PEOPLE CALL ME MAURICE,
ND13 wrote:I don't need the one with the Speedbooster, do I?
Maybe for heavy/graphic intense wireless gaming..
wireless g by itself is fast enough for just about anything...Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
I posted earlier. Looks like you guys have what you want.
Someone said earlier about leaving the wireless connection open. Always add a login password. Unless your neighbors are out of range. That happened to me for about a month. Then I realized that there were two PC's on the server.:cool:
