where to get materials and tools.
fgreco
I need to get all the tools and materials to put in a system I know how to do it. For example the clips to put on the wires. Please help give me a site or store.
Post edited by fgreco on
Parts Express carries a few things that may interest you.
Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
is that the website or a store. I dont have one of those stores here in NJ.
Hi,
It is a website.....www.partsexpress.com.....I have ordered from them a couple times and so have many others.
There are many many other places to get stuff too. If you were to narrow down your question and be a little more specific then others may reply too.
....Oh, Welcome to the Polk Forum....
Ok, I want to splice a wire and join it together with another wire. I need a clamp of some sort so the moisture dont get in and the wire comes apart one guy says he puts the wire in and then uses pliers to clamp it down.
You probably want butt joint clip things and electrical tape if you want to waterproof them. You can get them at radio shack. Idealy you would use a crimper to crimp the clips but you could use pliers. They look like this:
yes that is exactly what it is . Thanks
