where to get materials and tools.
fgreco
fgreco Posts: 6
edited September 2005 in Forum Testing Area
I need to get all the tools and materials to put in a system I know how to do it. For example the clips to put on the wires. Please help give me a site or store.
Post edited by fgreco on
  • PolknPepsi
    PolknPepsi Posts: 781
    edited August 2005
    Parts Express carries a few things that may interest you. :confused:
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • fgreco
    fgreco Posts: 6
    edited August 2005
    is that the website or a store. I dont have one of those stores here in NJ.
  • PolknPepsi
    edited August 2005
    Hi,
    It is a website.....www.partsexpress.com.....I have ordered from them a couple times and so have many others.
    There are many many other places to get stuff too. If you were to narrow down your question and be a little more specific then others may reply too.
    ....Oh, Welcome to the Polk Forum.... ;)
  • fgreco
    fgreco Posts: 6
    edited August 2005
    Ok, I want to splice a wire and join it together with another wire. I need a clamp of some sort so the moisture dont get in and the wire comes apart one guy says he puts the wire in and then uses pliers to clamp it down.
  • michael_w
    michael_w Posts: 2,813
    edited August 2005
    You probably want butt joint clip things and electrical tape if you want to waterproof them. You can get them at radio shack. Idealy you would use a crimper to crimp the clips but you could use pliers. They look like this:
  • fgreco
    fgreco Posts: 6
    yes that is exactly what it is . Thanks
