Biwiring with Monitor speakers and Harman Kardon receiver
bailey2952
bailey2952 Posts: 1
Hi, I'm a newbie, so I need some advice. I've decided to go ahead and try biwiring. I have Polk Monitor 30 speakers and a Harman Kardon HK 3480 receiver. If I biwire, can I use both the A and B speaker outputs? I did a search for biwiring on the forum already and someone with a similar idea had mixed responses (some said it would work, another said it wouldn't). Would I be able to do that? Should I? Also, is it worthwhile to get speaker connectors? Should I just get pins or banana connectors?
Thanks for all your help
Bailey
Post edited by bailey2952 on
    F1nut Posts: 51,803
    edited September 2005
    If your speakers have two sets of binding posts, then yes you can bi-wire them. Personally, I wouldn't bother especially with a receiver. Instead of bi-wiring, replace the stock jumpers with the same kind of wire you are using for speaker cable. You'll get better results for a lot less money.
    Speaker connectors??? Banana's, pins and spades are a way to terminate the ends of speaker cable, if that's what you're asking. I prefer banana's.
  • aaharvel
    aaharvel Posts: 4,489
    good advice. that's what i did with my 4's and made a noticeable difference (calmed the tweeter down a bit)- I took the jumpers off and replaced them with 4 inches of 14g speaker wire, then I used banana plugs to terminate.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
