MP3 to audio CD problems
shepx2
shepx2 Posts: 646
edited April 2024 in Clubhouse Archives
OK, maybe someone here can help me out. I've tried to convert 3 or 4 mp3 files to CD, and every time they come out skipping and jumping to other tracks. The first track always seems to be fine, but any after that seem to be affected. I've tried a couple different programs for conversion, and still the same thing. I also tried 2 CD's I ripped myself using Cdex, and still have the same problem when going back to CD.
Any other ideas? My drive is a Plexor 712a DVD/RW drive. It burns everything else fine, including copying a CD. I'm out of ideas on what the problem could be.
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2005
    Hmm. You've got me. Never really had much of a problem with ripping/burning MP3. Are you burning them as MP3? Or are converting to .wav and burning? Or are you converting to MP3 and then burning?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • shepx2
    shepx2 Posts: 646
    edited August 2005
    I'm converting them to .wav then burning.
    VR3 Posts: 29,549
    edited August 2005
    May be an issue with your CD-Writer.
    I have had a friend have similar issues. It played/copied fine, but when it came to burning - it was always in a dissagreement.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2005
    At one time there were a lot of butchered mp3 files posted to interfere with illegal downloads.
  • shepx2
    shepx2 Posts: 646
    edited August 2005
    This shouldn't be the case with stuff I have ripped myself. And my drive burns EVERYTHING else fine. DVD's from my video camera, picture CD's, my backup recovery disks, everything. And, as I said, If I copy a CD to my hard drive and keep it in .wav, then burn it to another CD, it works fine too.
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    What Burning Software are you using?
  • shepx2
    shepx2 Posts: 646
    edited August 2005
    I've tried Roxio and the PlexTools. Nero doesn't seem to like this drive for some reason, so can't use that anymore.
    billbillw Posts: 7,792
    edited August 2005
    Nero works the best for everything. You can burn MP3s directly to disk and Nero automatically converts them to wav fiiles. I've never had a bad disk. PlexTools is crap and I'm not too fond of Roxio. Despite that, most people have no troubles with Roxio software.
    Make sure you have the IDE port for your burner set to the highest data rate have enabled DMA. Also make sure you have the latest chipset drivers for your motherboard. These are all things that can affect CD burning.
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    ^x2... I was about to suggest Nero but Bill did it first so...
  • shepx2
    shepx2 Posts: 646
    edited August 2005
    All hardware drivers on my computer are up to date; I check for updates once a month.
    As far as Nero, as I said, it does NOT like this drive for some reason. It will not burn anything without an error.
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited August 2005
    This may clear it up, or not. But I had the same issue with burning discs on my computer. It turned out to be the CD itself. I was attempting to burn Audio Only discs that are made for stand alone CD Recorders. My CD Recorder went belly up and I had a lot of the Audio Discs lying around. Burning to them type of discs had the same problem you are having. The first couple songs burned were fine, then they started skipping. I went to a CD-R and they came out fine. So check if you have CD Audio only discs...
    scott
  • shepx2
    shepx2 Posts: 646
    edited August 2005
    No, that's not it. These are CD-R computer-drive disks, made by Mitsubishi, which are one of the few recommended by Plextor.
