any chance of breathing life into my BSR CDP?
nadams
nadams Posts: 5,877
edited August 2005 in Electronics
As some of you may remember, I purchased a BSR 2020MKii CDP off of eBay, on the recommendation of the members here. Unfortunately, it worked fine for a little while then started giving me fits. At first, it was just a rubber band that needed replacing, then it stopped altogether.
If I put a CD in the tray and hit play, it'll pull the tray in, but not do anything (won't read CD contents, won't start playing, won't even spin the CD a little). I tested all the motors using a battery, and they all spin freely. When I close the CD tray with no CD in it, the laser doesn't light up at all. It doesn't try to find a CD or anything...
But when I turn it on or off, the laser will flash for 1/2 second, so I know that it CAN get power.
I'm guessing somethings amiss w/ the control board, but I can't figure anything out. I'm guessing it's junk, but I've been hanging on to it, because I paid $55 for it :(
Ludicrous gibs!
Post edited by nadams on
  • nadams
    nadams Posts: 5,877
    edited August 2005
    Haha... found the thread where I was doing a mini-review. RuSsMaN's comment:
    "I figure you'll keep that bad boy until the laser dies. Good on ya."
    Ludicrous gibs!
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2005
    I have a couple things in the gear swap that will run circles around that BSR. Come on down.... :)
  • nadams
    nadams Posts: 5,877
    edited August 2005
    I'll be down, but only for Friday's tour...
    Ludicrous gibs!
  • dorokusai
    edited August 2005
    Well, the list is in the information thread....only a couple, let me know what you want and I'll bring it with me.
  • izafar
    izafar Posts: 819
    edited August 2005
    http://repairfaq.ece.drexel.edu/sam/cdfaq.htm
    This is a very comprehinsive writeup for DYI CD Player trouble shooting and fixing
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • nadams
    nadams Posts: 5,877
    edited August 2005
    izafar- great resource! Unfortunately, it would appear that this thing is beyond my scope to fix. Guess sometimes **** happens :)
    doro- I looked through the list... no prices on anything :( I understand the whole premise of the for sale/trade, but letting you know what I want would be much easier if I knew that I could afford it. For instance, I'd like those SDA CRS', but I sure as hell can't afford 'em :D
    Ludicrous gibs!
  • dorokusai
    edited August 2005
    PM me, we'll discuss details. I didn't want to list prices because the deals are really for those in attendance, but I'll get you square....it's on the cheap honcho.
