FM Antenna
audiobliss
audiobliss Posts: 12,518
edited August 2005 in Electronics
While I'm amazed at how well the little wire that came with my receiver picks up FM stations, a lot of stations do sound fuzzy; I can't even get some. One antenna I've seen in several Audio Advisor catalogs has caught my eye. The Godar Electronics' FM-1a. It's passive and connects via a 75ohm cable. That should work fine with my receiver, right? Would you recommend it? Would you recommend something different? Remember budget, as this ($60) is about the limit.
http://audioadvisor.com/store/productdetail.asp?sku=GODFM1A&product_name=FM-1A%20FM%20Antenna
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited August 2005
    I have this antenna for my upstairs system. It seems to do a pretty good job even on a few fringe signals. It definitely performs best if it can be located as close to a window as possible. :)
    Robbie
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
  • audiobliss
    edited August 2005
    Thanks, appreciate the input. It would most likely be located about 5.5' from the floor and about 6' from a window, with nothing inbetween. That's pretty close to a window.
    I'll see if I can't set aside some money for it, then. Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • bikezappa
    bikezappa Posts: 2,463
    edited August 2005
    Just get a RS set of rabbit ears for $10.
  • pjdami
    pjdami Posts: 1,894
    edited August 2005
    I have the Godar antenna and the FM Reflect antenna from C. Crane Company. The FM Reflect kicks its **** in my opinion. Only negative is that it is big and bulky so if the way it looks hanging on your wall is a concern then its up to you.
    Steveinaz recommended the C. Crane antenna a while back. For $25 its hard to beat.
    http://www.ccrane.com/antennas/fm-antennas/fm-reflect-antenna.aspx
  • mrmusicman
    mrmusicman Posts: 303
    edited August 2005
    Screw FM! :p
    XM sat rules :D
    Outlaw 990 Processor
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    Kenwood Excelon KDC-X891
    JL Audio 300/V2
    Polk Audio SR 6500 - Fronts
    Polk Audio DB651 - Rear
    2 -10" Treo Subs
    Interfire IB 2600C sub amp
    Sirius Sat radio
    Ipod connection
  • dkg999
    dkg999 Posts: 5,647
    edited August 2005
    I have two of the Godar antenna's, one of them is about 18" wide and the other one is about 42" wide. They are picky on placement, but in my all-brick apt. which has absolutely crappy radio reception, once I have them placed I am very impressed with them. I really don't have much to compare them to, except for the Terk antenna I tried.
    DKG999
  • audiobliss
    edited August 2005
    Yeah, size and appearance are important. And availability. I've never been able to order online before, but I'm hoping I'll be able to convince the parents that Audio Advisor is sound enough. Thanks for the input, guys!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • unbridled_id
    unbridled_id Posts: 179
    edited August 2005
    I just ordered the c-crane reflect antenna. I use a cheap dipole and was considering the godar but felt since I could not put it near a window it would be less effective. I own a nad c422, and am in a basement, reception is good on strong stations but fringe stations have trouble locking in or are non-existant.
    The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
    Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince.
    SCompRacer Posts: 9,112
    edited August 2005
    They look good according to BizRate.
    http://www.bizrate.com/ratings_guide/cust_reviews__mid--18818.html
    If you do order online with a credit card, during checkout watch for a box that might be checked where they save your credit card number on file. Online etailers having that feature usually have that box checked by default. If they get hacked, at least your number shouldn't be there for the taking.
  • audiobliss
    edited August 2005
    unbridled_id - C Crane reflect antenna; what's that? You like it?
    SCompRacer - Thanks for the tip. I'll really hafta remember that.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • unbridled_id
    edited August 2005
    Audiobliss, the ccrane reflect antenna is a thick dipole, which according to their website and some other folks is a distinct improvement upon the standard ratshack dipole. It's 25 dollars and has a 30 day return so I figured what can I lose. Ccrane is that company that advertises on talk radio sometimes about their led flashlights and portable radios.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2005
    I just have a homeless guy stand in the yard with a 25ft. Channel Master duct taped to his back.....reception is excellent, and fully adjustable.
  • sucks2beme
    sucks2beme Posts: 5,686
    edited August 2005
    I've got a Radio Shack fm antenna in the attic. Running the cable was a pain, but it works better than anything else I've tried. For FM reception, nothing beats a good antenna up high. Amplification only works if there's a clean signal there to begin with. All the high priced stuff I tried ended up being returned.
  • unbridled_id
    edited August 2005
    Hey dorokusai, you best be careful, if your homeless guy antenna gets struck by lightning his next of kin may sue you.
  • unbridled_id
    edited August 2005
    I agree an antenna high up will garner the best results. I used a terk amplified antenna and I was shocked to find it inferior to a simple dipole !
  • audiobliss
    edited August 2005
    Hmmm. That is a great idea. Where do you get these, 'homeless guys'? Sounds like it should clear everything up just fine!
    unbridled_id - Where can you buy that CCrane antenna you're talking about? Do you have to order from their website? (And what is their website?) I may just wait 'till you get yours so I can see what you think.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • dorokusai
    edited August 2005
    I live outside of DC man....c'mon :)
  • audiobliss
    edited August 2005
    ROFL
    Could you snag one for me and ship it down here? Make sure he's strong enough to stand for long periods of time!!
    :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • dorokusai
    edited August 2005
    Unfortunately they are extremely unreliable and I have to chase my hobo/FM Antenna down the street every other week....he's pretty slow physically. I have inserted a GPS transmitter in his neck so I can locate him in my work truck. Obviously he doesn't know a good gig when he sees it....damn wanna-be musicians :(
  • audiobliss
    edited August 2005
    Oh. Well, I had no idea they were so high-maintenance. I believe I just might look at a more traditional antenna like I suggested the start with. Thanks, though!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited August 2005
    Oh man, I just realized that the antenna that undridled_id and pjdami are talking about are the same thing! LOL
    So, from looking at the picture on their website, is the 53-inch part the piece that goes across the top and is the 'J' looking part the 80-foot cord? Or is all that the antenna and then the cord hooks to the end of that? Because if just the top part is the antenna and the rest is the cord, that should probably work in my room just fine.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
