FM Antenna
audiobliss
While I'm amazed at how well the little wire that came with my receiver picks up FM stations, a lot of stations do sound fuzzy; I can't even get some. One antenna I've seen in several Audio Advisor catalogs has caught my eye. The Godar Electronics' FM-1a. It's passive and connects via a 75ohm cable. That should work fine with my receiver, right? Would you recommend it? Would you recommend something different? Remember budget, as this ($60) is about the limit.
http://audioadvisor.com/store/productdetail.asp?sku=GODFM1A&product_name=FM-1A%20FM%20Antenna
Thanks!
Thanks!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
I have this antenna for my upstairs system. It seems to do a pretty good job even on a few fringe signals. It definitely performs best if it can be located as close to a window as possible.
RobbieMain System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
Thanks, appreciate the input. It would most likely be located about 5.5' from the floor and about 6' from a window, with nothing inbetween. That's pretty close to a window.
I'll see if I can't set aside some money for it, then. Thanks!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Just get a RS set of rabbit ears for $10.
I have the Godar antenna and the FM Reflect antenna from C. Crane Company. The FM Reflect kicks its **** in my opinion. Only negative is that it is big and bulky so if the way it looks hanging on your wall is a concern then its up to you.
Steveinaz recommended the C. Crane antenna a while back. For $25 its hard to beat.
http://www.ccrane.com/antennas/fm-antennas/fm-reflect-antenna.aspx -
Screw FM!
XM sat rules
Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
I have two of the Godar antenna's, one of them is about 18" wide and the other one is about 42" wide. They are picky on placement, but in my all-brick apt. which has absolutely crappy radio reception, once I have them placed I am very impressed with them. I really don't have much to compare them to, except for the Terk antenna I tried.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Yeah, size and appearance are important. And availability. I've never been able to order online before, but I'm hoping I'll be able to convince the parents that Audio Advisor is sound enough. Thanks for the input, guys!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I just ordered the c-crane reflect antenna. I use a cheap dipole and was considering the godar but felt since I could not put it near a window it would be less effective. I own a nad c422, and am in a basement, reception is good on strong stations but fringe stations have trouble locking in or are non-existant.The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. -
audiobliss wrote:Yeah, size and appearance are important. And availability. I've never been able to order online before, but I'm hoping I'll be able to convince the parents that Audio Advisor is sound enough.
They look good according to BizRate.
http://www.bizrate.com/ratings_guide/cust_reviews__mid--18818.html
If you do order online with a credit card, during checkout watch for a box that might be checked where they save your credit card number on file. Online etailers having that feature usually have that box checked by default. If they get hacked, at least your number shouldn't be there for the taking.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
unbridled_id - C Crane reflect antenna; what's that? You like it?
SCompRacer - Thanks for the tip. I'll really hafta remember that.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Audiobliss, the ccrane reflect antenna is a thick dipole, which according to their website and some other folks is a distinct improvement upon the standard ratshack dipole. It's 25 dollars and has a 30 day return so I figured what can I lose. Ccrane is that company that advertises on talk radio sometimes about their led flashlights and portable radios.The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
I just have a homeless guy stand in the yard with a 25ft. Channel Master duct taped to his back.....reception is excellent, and fully adjustable.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I've got a Radio Shack fm antenna in the attic. Running the cable was a pain, but it works better than anything else I've tried. For FM reception, nothing beats a good antenna up high. Amplification only works if there's a clean signal there to begin with. All the high priced stuff I tried ended up being returned."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
Hey dorokusai, you best be careful, if your homeless guy antenna gets struck by lightning his next of kin may sue you.The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
I agree an antenna high up will garner the best results. I used a terk amplified antenna and I was shocked to find it inferior to a simple dipole !The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
dorokusai wrote:I just have a homeless guy stand in the yard with a 25ft. Channel Master duct taped to his back.....reception is excellent, and fully adjustable.
Hmmm. That is a great idea. Where do you get these, 'homeless guys'? Sounds like it should clear everything up just fine!
unbridled_id - Where can you buy that CCrane antenna you're talking about? Do you have to order from their website? (And what is their website?) I may just wait 'till you get yours so I can see what you think.
Thanks!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I live outside of DC man....c'mon
CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
ROFL
Could you snag one for me and ship it down here? Make sure he's strong enough to stand for long periods of time!!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Unfortunately they are extremely unreliable and I have to chase my hobo/FM Antenna down the street every other week....he's pretty slow physically. I have inserted a GPS transmitter in his neck so I can locate him in my work truck. Obviously he doesn't know a good gig when he sees it....damn wanna-be musicians
Oh. Well, I had no idea they were so high-maintenance. I believe I just might look at a more traditional antenna like I suggested the start with. Thanks, though!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Oh man, I just realized that the antenna that undridled_id and pjdami are talking about are the same thing! LOL
So, from looking at the picture on their website, is the 53-inch part the piece that goes across the top and is the 'J' looking part the 80-foot cord? Or is all that the antenna and then the cord hooks to the end of that? Because if just the top part is the antenna and the rest is the cord, that should probably work in my room just fine.
Thanks!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
