Caps and resistors
KUTTO
I've tried several online partstores but haven't been able to find the ones I need.
Is it possible (or OK) to put ones with slightly higher values?
Caps (ac)
34uF-50VAC
12uF-50VAC
Resistors
2.7Ω 10%5W
6.2Ω 10%5W -
Mills Resistors, http://www.partsconnexion.com/catalog/resistors.html
2R7 = 2.7ohms 1% 5 watt
6R2 = 6.2ohms 1% 5 watt
Solen Caps, http://www.partsconnexion.com/catalog/CapacitorsFilm.html
12uF 400V 5%
33uF 400V and piggyback a 1.0 400V = 34uf 400V 5%
The cheap stock electrolytic caps have a lower V rating, you want to upgrade. -
Thank you very much,F1nut.
I ordered them this morning.
