SONY DAV-SC5 5.1 Channel DVD Player
helpneeded
hi,
i have got a sony dvd player 5.1 channel model dav-sc5. i bought it last year and now like from a month i'm facing this problem with the center speaker that it is not giving the proper sound it should give. there are some krrrrrrr..... sounds coming out of thr speaker and somtimes there is good sound and after a minute it goes again. i cant figure out wht the problem is and dont want 2 go to the dealer bcoz i know they r gonna give me a huge bill of maintenance and repairs. so plz if any 1 has any knowledge abt the speaker and how i can fix it plz tell me. u can contact me on the email or just reply on this thread.
thnx in advance...
have a nice day guys
thnx in advance...
Post edited by helpneeded on
Well *your problem is the sony unit because sony makes lousy avrs and htib which is what I beleive what you have , if I were you I would ditch the sony and get a better system since the repair will cost more than a new unit.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
when something like this happens in the car, it's often the fault of the speaker, perhaps you can take out the midranges from the center speaker, see if there's any loose wires... can't hurt, cause lou is right, repair isn't worth it... how much were you planning to spend on the repair?It's not good, very fundamentally simply not good. - geolemon
Welcome...are you sure it's the player and not something else? Before sending the unit for repair you should try to isolate the issue...could be the player, or the receiver/amp, or the speaker, or a bad connection...._________________________________________________
As HTrookie said, try and single out a problem. See if its the speaker. Can you reproduce the same poor results with a different speaker? Try using the faulty speaker with a different channel. Try borrowing a different AVR/DVD player. I assume you've tried different DVDs?
Call around for price quotes on repairs. You'll be suprised sometimes at how cheaply it can be done.
