In-Ceiling Speakers and Blown In Insulation
kyctfan
kyctfan Posts: 1
If you install speakers in a ceiling then have blown in insulation applied, do you need to remove the insulation around these speakers or will they sound ok with direct contact to the insulation?
Post edited by kyctfan on
  • mantis
    mantis Posts: 17,333
    edited August 2005
    You need not remove the insulation. Actually it will improve the sound quality. Tighter bass is the result.
    Dan
    Dan
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2005
    Isn't best to use a form speaker box?
    I could be wrong I had trouble finding a link of one.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    SCompRacer Posts: 9,097
    edited August 2005
    Steve, were you referring to these? Nice, buy pricey. I built my own and used the coin in other areas. Ken of Polk had told me that the LC series in-wall/ceiling speakers benefit the most from an exact volume enclosure while the others did not.
    I'd be concerned about the blown in insulation working in around the backside of the driver. I would lay a piece of blanket insulation over the speakers before the blown in insulation were applied. Building code here for ceilings is blanket insulation with a vapor barrier with blown in on top of that.
