Holy Carp! $199 DVD player beats them all except the 5910
PolkThug
Oppo Digital - OPDV971H
Excellent DVI out and works with HDTV's that aren't HDCP compliant also.
**Also comes with a DVI or DVI-HDMI cable when you buy new.
http://www.hometheaterhifi.com/cgi-bin/shootout.cgi?function=search&articles=all&type=&manufacturer=0&maxprice=0&deInt=0&mpeg=0
Post edited by PolkThug on
a buddy of mine was telling me about this player. Looks VERY impressive. Just to bad it doesn't do SACD (does do DVDa though). I've heard it hangs with a 3910. IMPRESSIVE!Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Hmmm, only outputs video above 480i via its DVI board. Won't do progressive scan video over component video cables. Seems like a product still in the design phases, although the video performance seems good for what it does do. Oppo may be products to keep an eye on for the future.
This looks impressive..does anyone know where it can be purchased?2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
Roy Munson wrote:This looks impressive..does anyone know where it can be purchased?For rig details, see my profile. Nothing here anymore...
Amazon sells em too. Same price as Oppo Digital's but with free shipping I think.
http://www.amazon.com/exec/obidos/tg/detail/-/B00078GLJY/qid=1124084400/sr=8-1/ref=pd_bbs_1/102-0888943-0931344?v=glance&s=electronics&n=507846
Nice DVD player, good review and from what I read, good cs too. -
I have had mine for 2 weeks now so I guess I will post my findings on the product.
Positives:
To start with, this player has the best picture I have ever seen on any DVD player, simply amazing**(you must have DVI/HDMI on your TV for this to work)**. Once you play back movies you know have bad distortions, you will have a hard time finding them.
The real life motion software adds a nice 3D touch to your movies without over accentuating the process i.e. Philips has the same process built into some of their TV's, but it's over enhancement causes too much motion blur.
The remotes response to menu selection is fast and smooth and the built in 8MB buffer also makes for seamless layer changes without any noticeable stopping.
The units software tweaks are extensive allowing you to adjust picture quality with sharpness, color, brightness and contrast. Sound setup allows the user to setup speaker configurations, timing and volume levels and a lip-sync adjustment of 10-50ms.
Negatives:
This is probably the worst thing about the player that the reviewer does not talk about and that is the audio alignment ( this only applies if you are using the digital audio out into a receiver or pre-pro). Even though it has a lip-sync feature is does not align the sound with the picture. It seems I have to adjust the sound for every movie from 30-50ms and even if you think it looks right the pitch gets thrown off and you still do not get a clean sync throughout the movie. This is the worst case of alignment I have ever seen on any DVD player.
The remote control is not well laid out and is next to impossible to use during a dark showing because there is no backlighting at all.
Neutrals:
Build quality is about what you would expect from a sub $200 player. The tray consists of a thin piece of clear molded plastic thats flimsy, so keep the kids away from this one. The tray well is not very deep, so make sure your discs are seated properly before you hit the eject button or jams and scratches will occur.
Conclusion:
If you love old Japanese movies and you want the absolute best picture quality at rock bottom prices. I have to say the picture quality alone is worth the asking price. :cool:
-Jer"The only way to get rid of a temptation is to yield to it." -
Great information, Jerry. Thanks for sharing.
Good info, Secrets only tests video. I think I will buy the next iteration of this one.
but I don't like that it doesn't go progressive via Component... otherwise I'd give it a shot (when the audio gets fixed of course).Never kick a fresh **** on a hot day.
Thanks Jerry, I might just give this a try after I thing about it a little more.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
yes, i've had mine for about a week now via amazon.com. free shipping. adequate packaging. anyway, i already had a nice progressive scan dvd player hooked through components. not bad. but one could NEVER compare it to anything near high def pic quality. i was gonna go the samsung hd-931 over a year ago, but waited. good thing i did. got the oppo and coulnd't be happier. first, get the negative out of the way. no illumination on the remote. second, when you play an audio disc, there is no on screen display showing the track #. but the mp3 playing is nice. haven't tried dvd-audio yet, but can't wait.
now for the picture quality!............watching I, Robot i found myself thinking i was watching a near hdtv broadcast via my hughes e86 directv high def box. nothing compares to hd besides real life, but man, oh man, this baby comes close! dull colors from my old progressive scan samsung were all washed out. this puppy makes dem colors look the way there were meant to be presented in. one can use the speaker set-up menu to accomplish sound management, but i save that to use on my h/k 7300.
dvd region free just as they say, but you must access their secret icon menu. mine is set to 0 (region free) but i have only region one discs. maybe i'll make use of that in the future. all in all, i love this dvd player. glad i waited for oppo as "oppo"sed to going with the samsung up-converters!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
btw.....i haven't messed around with my avia dvd yet. picture is already so excellent. i just pop dvd's in and relax and enjoy. the blue lighting to it matches all my other components as well. looky good! one more big negative though......if you turn the unit off during the middle of a movie and continue watching it later, you'll have to start from the beginning.........can't have everything.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
so did you not find the same audio delay issues as jrausch?
once i did. but i honestly believe it was due to me moving my satellite receiver around which sits directly atop the oppo. i was watching a movie and decided to put a piece of cardboard in between the sat receiver and the oppo to keep the heat coming from the sat off of the oppo. i was bumpin' shizz around. i just hit the stop button and then hit play and it was all sync'ed up again. must've been from bumping it for sure!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
one more note........i go into the h/k 7300 via coaxial and not the optical.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
ah, that may make a difference as well. I'd also be going via coaxial as I prefer it over optical just a bit...
polkmaniac, you gonna get this player? i say go for it! i can't wait any longer for hddvd or blu-ray. this makes me smile until hd becomes available. and as with all new technologies.......the first batch of player and their medium will be very highly priced!!!!!!! poor saps who have huge libraries of dvds. just as people had to rebuild their collection from vhs to dvd, the same will apply. some will be content with the now mainstream dvd. many will wish to upgrade. i will build my library when hd-dvd comes down in price.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
BIZILL wrote:polkmaniac, you gonna get this player? i say go for it! i can't wait any longer for hddvd or blu-ray. this makes me smile until hd becomes available. and as with all new technologies.......the first batch of player and their medium will be very highly priced!!!!!!! poor saps who have huge libraries of dvds. just as people had to rebuild their collection from vhs to dvd, the same will apply. some will be content with the now mainstream dvd. many will wish to upgrade. i will build my library when hd-dvd comes down in price.
When you build a collection you have to know that eventually it will be replaced. The hard part is to keep up with technology but not get caught up in a fad that is really short lived like those massive laser discs. -
i'm sure that when hd dvd finally agrees upon one format (hddvd vs sony blu ray) that that should remain the standard for quite some time. high def vhs has been around for awhile. but who wants the unreliability of magnetic tape? optical disk with its direct seek capabilities has proven to be the standard. (cd's and dvd's) all we are doing is just refining the good 'ole optical disc. next big leap i'd imagine would be some holographic 3-d shizz. we are already immersed in three dimensional sound. how'z 'bout being enveloped in 3-dimensional visual content!!!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Anyone else have this player yet? It's making the news waves.
http://www.courant.com/technology/hc-hunt1021oct21col,0,6658286.column?coll=hc-utility-technologyPolk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111 -
I own one of these players and I did have some trouble at first in that i needed to update the firmware and remote in order for it to funciton properly. Initially i was a little frustrated but the service department at Oppo is amazing, responding to emails i sent late on a Sunday evening. The service department went out of their way to make sure my dvd player and remote were working properly.
If you are looking for a DVD player on a budget, you wont be disappointed with this player. Being able to play just about any disc and format you throw at it is a nice touch too. Nearly made my HTPC absolete =P
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
this may sound dumb but... how do you hook the oppo up? Would I run the dvi into my tv-hitachi 46f and the optical or coaxial to the yamaha 2500 for sound? I am a little confused.
snakebitten wrote:this may sound dumb but... how do you hook the oppo up? Would I run the dvi into my tv-hitachi 46f and the optical or coaxial to the yamaha 2500 for sound? I am a little confused.
yes.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Anyone know how the audio quality compares to higher-end players like the Denon 2900 and 3800 series; specifically in direct mode? For $200, it almost seems to good to be true, especially for those that spent good amounts of money on "higher-end" players.____________________________________________________________ polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS SVS PB13 Ultra x 2Pass Labs X1, Marantz 7704, Sunfire Signature Cinema Grande 400, ADCOM 7807, Panasonic UB420, Sony SCD-C333ES, EPSON Pro Cinema 6050
dunno, haven't heard any "higher-end" players. "higher-end" being synonymous with "more expensive".
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
i might have to get one befor they are made ilegal.
Any updates on how this dvd player works? Any problems?
had mine about 3-4 months now and am happy with it. every now in a great while i'll have a lip synch prob. just hit stop and play again and it's gone. mp3 playing is done on-screen via your television. regular cd playing utilizes no television interface, bummer. all in all a great little dvd player. would not think twice or hesitate getting it.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
i've had mine about 2 months now i think, about a month since i got all the update/remote kinks worked out. Seems to work fine, i've never noticed any lip synch problems, but i only watch movies on it maybe once every 2 weeks or so. Looks great with my Plasma TV and sounds fine on my HT. I recommend it...
Pre: Dodd ELP
DAC: W4S-Dac2
well, they do keep updating the firmware. thats a good sign :rolleyes: I've had mine for 4 months and its really nice. Not great however, since the remote is trash, and the design isnt the nicest... and it comes abit too satuated out of the box. other then that its a good bargin but not the best...
