New Tweeter Day
SCompRacer
SCompRacer Posts: 8,363
edited August 2005 in Vintage Speakers
Got these RD0194 replacements for the SL2000's in my SRS 2's today. Ordered Monday from Helen, here Friday. I like the service.
Is it true that after installing replacement tweeters, burn in must be uninterrupted and continuous with a variety of music? So maybe I shouldn't go in to work tonight? :D
I thought I was starting to like the brightness of the silver domes, but I was wrong. Caps and resistors next.
Post edited by SCompRacer on
  • madmax
    madmax Posts: 12,434
    edited August 2005
    The RDO's do take a little time to break in. Yes, you should stay home to vary the type of music. (I did when I got mine. :))
    madmax
    Vinyl, the final frontier...
  • ND13
    ND13 Posts: 7,601
    edited August 2005
    ;):D Make yourself a mix CD and put cd player on repeat and go to work so you can keep the cash flow going so that you can continue with the upgraditus
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2005
    Best idea of all! :D
  • ND13
    ND13 Posts: 7,601
    edited August 2005
    Hi Cathy. How ya been lately?
    edited August 2005
    Hey, there ain't no instant gratification in that!! ;)
    What I need to do is have the MIL walk the dog so's I can give em some serious juju from the TFM-35's in bridged mono. Kinda like seating rings in a fresh motor, occasional blasts of acceleration before coasting.:D
  • cfrizz
    edited August 2005
    Hi Noel! Been fine, getting excited about about the PolkFest! I get to see my brother & talk audio all at the same time. It doesn't get much better than that!
  • trubluluc
    trubluluc Posts: 2,067
    edited August 2005
    ....This is the perfect excuse to buy yourself a 300-400 CD changer and just let it ride.
    I love mine.
    -Luc
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited August 2005
    Can you explain in detail how you are running your tfm-35 in mono? Do you have the modified IC? I have a couple tfm-45's that I would like to try running mono with my sda's
    edited August 2005
    The TFM-35/35X has a stereo/mono switch on the back panel. (If a slide switch lock is present, loosen the lock screws to slide the switch to the desired position). I haven't seen the back of a TFM-45 though I'd like to get my hands on one. The 45 and 55 have the true transfer function while I was told the TFM-35/35X, 45X and 55X do not.
    In mono, connect the R & L pre amp outputs to the left channel input of each amp. Connect the R & L speaker wires to the red positive terminals on each amp; speaker positive to the left positive and speaker negative to the right positive.
    If it applies to your SDA speakers, swap out the standard SDA interconnect for the non-common ground amplifier interface and rock on. :cool:
    EDIT: Add scanned bridged mono page from TFM-35X manual.
  • candyliquor35m
    edited August 2005
    Do you have the non-common ground IC?
    edited August 2005
    Yes I do. The guy I bought the SDA's from had everything but the boxes but was missing one foot. I got a replacement from Polk.
    EDIT: If you need to make one, follow the link to the instructions from this page. This is off of forum member polksda's site. http://www.polksda.com/links.shtml Look under Publications, A1 interconnect.
  • candyliquor35m
    edited August 2005
    Thanks but my SDA's are too early for the A1IC according to the chart so I am still bi-amping my tfm 45 and 42 which are sonically the same amp except the 45 has a meter and the 42 has a led I guess you would call it. I thought maybe you were connecting the negative speakers post that I've heard about but both Polk and Carver say would not accomplish a common ground.
  • trubluluc
    edited August 2005
    .....if so, we'd like to see a picture of those little black beauties. :)
    Mine should be here by Wed. or so.
    -Luc
    edited August 2005
    Out with the old....and in with the new. Did it that Friday and burned a vaca day listening to tunes. I been working too hard.
    I picked up a used Bello audio rack off of craigslist for a reasonable price so now my stuff is off the floor. Much easier to play CD's now....
