need advise
cupojo
cupojo Posts: 3
edited August 2005 in Speakers
I am setting up a modest home theater system and recently bought the Polk RM6750 set of speakers. Problem is that the back speakers need to be in ceiling, since there is no wall behind, it opens up into another room. So instead of the ones that come with the system, I need 2 in ceiling speakers. Are there any that work better with the Polks than others? Hopefully $150 max for two. Also, I need a A/V receiver. Any suggestion that work well with the Polks? Max around $300. Thanks.
Post edited by cupojo on
    F1nut Posts: 51,690
    edited August 2005
    You can always put the back speakers on stands.
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2005
    Or suspend them from the ceiling...try a set of Omnimounts.
  • cupojo
    cupojo Posts: 3
    edited August 2005
    no,no, they HAVE to go in the ceiling, i got kids running around and a wife to please.
    so please give me some good suggestions
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2005
    Have you tried looking at the inwalls offered on Polk's website? Just make sure you get aimable tweeters. I wouldn't worry too much about timbre matching for back surrounds either.
  • cupojo
    cupojo Posts: 3
    edited August 2005
    yes,i've looked at the Polk ceiling speakers. But that is just my question, it is best to get Polk, since my other speakers are, or can I get any brand?
    Any suggestions on a nice receiver yet?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2005
    I'd get the best Denon you can afford for $300, definitely check in to used receivers given your price...
  • louthewiz
    louthewiz Posts: 581
    edited August 2005
    Get 2 MKIIs and put them on the ceiling like I did, and chek www.ecost.com for some nice refurbed denons and onkyos. :rolleyes: :D
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
