WTB Polk LS f/x speaker grille covers
chitsky
Good evening. I am looking for at least 1 pair of Polk LS f/x speaker grille covers. My toddler son has managed to break 2 of them :eek: . Each speaker has 2 grille covers measuring ~10"H x 6.5"W.
I contacted Polk and was told that there are no replacement covers available for this model.
Thank you to mjr7531 for pointing me to this forum. I am new to the Club.
Thank you all for your help.
Post edited by chitsky on
You might try some crazy glue and reclothing the speaker's covers ,I was able to fix my covers and it was easy, all you need to do is go to a fabric store and get the cloth.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Actually, the grilles are fine- it's the little plastic pegs that insert into the speakers that have broken off of the grilles (all 4 on 1 grille and 2 on another). I couldn't find all of the broken pegs, but I could probably find a substitute peg of the same diameter. I'll give the crazy glue a try.
Remember that your creativity is only limited by your imagination. LouMy gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
