New 2-channel DIY speaker project
The ones paul h made are absolutly stunning. I'd love to make a pair like that but need to read up on building crossovers first
michael_w wrote:The ones paul h made are absolutly stunning. I'd love to make a pair like that but need to read up on building crossovers first
Yeah I love the curved sidewalls and the dark stain with the huge gold woofers.
The crossover isn't too hard to build. Soldering takes a little practise but other than that you just copyh the layout.Graham -
I just measured the speakers in Speaker Workshop. Everything checks out. I'll post the frequency response as soon as I can. I am so relieved, if anything went wrong, I would have had to cut the boxes open to get at the crossover boards.Graham
Here is a quick frequecy response plot. This is quite flat but it is not the whole story. A on-axis FR plot is like the peak horsepower number. It's interesting, but over rated and only tells a small part of the story. You still dont know + or - 15, 30, 45 degrees horizontal and vertical. It doesn't give any indication of group delay, distortion, decay, etc etc. The speakers should be flat from about 50 Hz to 30 kHz.
Anyway, this was done far field ungated MLS at a distance of about 50 cm. I used a RS meter and Speaker Workshop. The RS meter is limited in accuracy and is only good up to several thousand Hz. I use this mainly to make sure the crossover is working properly and everything is wired correctly.
The results are 1/3 octave smoothed.
I'm very happy with this. Now it's on to finishing the cabinets.Graham -
Here are some pics of the weigh in. It measured exactly 50.0 lbs!
No wonder cement isn't very popular for speaker enclosures. Graham -
looks like a hernia and a half. but heres the real question, how do they sound??
With cement won't sound waves bounce inside and cause lots of resonance problems or is it just so damn dense that it absorbs everything. I'm just thinking about when you're in a concrete building and what happens when you yell.
tecmo04 wrote:looks like a hernia and a half. but heres the real question, how do they sound??
Good.
But dont take my word for it. See below
andJakub wrote:I was at the Toronto DIY meet where these were auditioned extensively. The room there was quite large, and these speakers did very, very well. IMO they were the best speakers at the event, though in a smaller room the Dennis Murphy Seas excel + Ribbon tweet design would have given them a run. That right there should tell you something about the pedigree of the speaker. Kudos to Jon and Graham on these , I predict they will keep you happy for a long time.
http://www.polkaudio.com/forums/showpost.php?p=277714&postcount=38
This version will sound almost identical to the old version, other than this is sealed. The old cabinets were very substantial aswell. Butcher block and heavy bracing. They were just too big.Graham -
michael_w wrote:With cement won't sound waves bounce inside and cause lots of resonance problems or is it just so damn dense that it absorbs everything. I'm just thinking about when you're in a concrete building and what happens when you yell.
You dont end up with any resonances, nothing is resonating. But you're right, concrete or cement is poor at absorbing acoustic energy. You do, or can have reflections and standing waves (no standing waves in these boxes though). For that I am lining the box with polyfil, and lots of it. You dont want reflections hitting the back of the cone, it is inevitable, but you try to minimize it.
After doing more research on this, there are others who have lined their enclosures with cement. Works very well, except for the weight issue. Having two materials bonded together like this works even better for controlling resonances.Graham -
Sounds like a good idea. Who cares how much they weigh once they're in place
Polyfil should do well in taming the air bouncing around inside a bit. You could probably help kill any standing waves by rounding the inside corners with cement too. -
michael_w wrote:You could probably help kill any standing waves by rounding the inside corners with cement too.
The inside corners are rounded, but non-parallel walls or ratios of 1.62:1 help as well.
I dont have to worry since the entire enclosure is full, really full of huge 14 gauge inductors and caps bigger than D cell batteries.Graham -
gatemplin wrote:The inside corners are rounded, but non-parallel walls or ratios of 1.62:1 help as well.
Good to know for future projects thanks.
BTW where do you live? I'm asuming somewhere in canada because of the trailor park boys thing. I'm in steveston (BC). Just curious cause if you're close I'd be cool to check these beasts out and give them a listen. -
michael_w wrote:Good to know for future projects thanks.
Yeah I'm a trailer park addict. I live in Toronto now, but I'm moving to Waterloo in a couple weeks.Graham -
Mmmm that's too bad. Good luck with the move.
I love the show too but I always seem to be busy and don't have time to watch it when it is on. -
michael_w wrote:Mmmm that's too bad. Good luck with the move.
Well I'm just going off to school. Not a big move, just gotta pack some clothes and speakers!
Graham -
I'm finally done with the wood putty and 220 grit sanding now. Ready for the final base coat of satin black acrylic. Then I'll spray on some polyurethane clear coat.Graham
I didn't get them done in time unfortunately. But at least they work, which is the most important thing. Afterall, I'm in engineering, not arts.
I might get the painting done on one of my trips back home.Graham -
Hey Graham, those are looking very nice. I will have to wait till we meet either in TO or here in Ottawa to listen to those. Looking forward to it.
So now that they are all purty and functional what do you think them?
Willow wrote:Hey Graham, those are looking very nice. I will have to wait till we meet either in TO or here in Ottawa to listen to those. Looking forward to it.
Hey JF,
I plan to bring them up to Ottawa some time. I'll PM you when I know. Hope everything is still going well for you two.So now that they are all purty and functional what do you think them?
Well they sound great, at least everyone says they do. I tweaked the crossover to get it just the way I like it. I am very happy with them, it was a very fun project.Graham
