Problem with working tweeter
FutureAudio
I've Rti100 towers. Tweeter on my right tower does not work..I tried to check tweeter by supplying power from outside and tweeter seems to work alright. ( For a short time at low volume to avoid any damage )
Is there a fuse or something inside the speaker which needs replaced?
Thanks in advance.
Thanks in advance.
Main: 2xLsi15
Center: Csi40
Surrounds: 2xLsi7
Back centers: 1xcsi30
Subwoofer: SVS PB10-NSD
Asus STX sound card -> Harman Kardon AVR325 -> Adcom Amps
Center: Csi40
Surrounds: 2xLsi7
Post edited by FutureAudio on
You have a problem with the crossover.
The crossover should be located somewhere on the amp (wherever the terminals (where you plug the speaker up at) is located)...
You would need to remove the amp and look for anything wrong - something has probally come loose.
Call Ken at Polk CS and let him know your situation...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks.
I'll call them tomorrow.
Using my Csi40 as my right speaker atm :grins:Main: 2xLsi15
Center: Csi40
Surrounds: 2xLsi7
