Banana Plugs
edited October 2005 in Speakers
Connect the speaker wires.
General inquiry.
I read/hear about "bare wire", "pins", "spring loaded clips", "spades" and "banana plugs".
What are banana plugs and where do they stand in the quality of connecting speaker wires?
Post edited by unit731 on
Welcome!
    edited August 2005
    Here you go:
    http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/home/connections_glossary.html?page=gallery&term=speaker_wire_connectors
    Bare wire is just stripping the speaker wire and connecting it directly to the receiver/amp.
    Spring loaded clips are the type of speaker wire terminals on the back of the receiver/amp. It's pretty much self explanatory: push the spring loaded lever to open the speaker wire connector, insert the wire and let go. The spring connector uses tension to keep the wire connected.
    Bananas help to make speaker wire connection easier.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
    edited August 2005
    Only advantage of banana plugs (or any other terminator) is that they will not oxidize like bare wire. Also it makes connecting the wire to a reciever much easier. You can plug it right in the hole on the connector rather than unscrewing it and tightening it onto the bare wire.
    I personally do not terminate my speaker wire on either end. You will find it is a preference thing. Only thing about using bare wire is you will have to cut it back and expose some fresh wire about every year because it will oxidize.
    Depending on the binding posts on you speakers it is debatable if you will get a better connection with one or the other. Overall quality will not improve at all if you use Banana plugs. Is just used for what I stated above.
    Its nice to have banana plugs on the end that goes into the reciever/amp but I would leave the end that goes into the speakers as bare. Only reason I can see using a plug on the speaker end is if the binding posts on the speakers are too small or make it really hard to put in and take out the wire.
    Testing
    Testing
    Testing
    edited August 2005
    Th banana plugs make a superior speaker connection as opposed to bare wire ,there are also speaker pins which are also good but I like banana plugs all the way since they make a better mechanical connection and the wires look alot better .
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
    edited August 2005
    How do they make a better connection than a big fat strand of 12 guage?
    Links?
    Testing
    Testing
    Testing
    edited August 2005
    The whole thing is sort of debatable and I would say that bare wire will give the best connection. I use banana plugs on the speaker end of my 2 ch system simply because it makes it much more fun and easy to swap out speakers. They can be had for a reasonable price (no need to buy monster cable or anything pricy) and are worth giving a shot. If you enjoy constantly changing things in your system I'd say get banana's, and if you don't change stuff very often go for bare wire.
    edited August 2005
    It has always been a preference for my personal use since I have been using the for the past 20 years , and they have always made a non corrosive contact between copper and aluminum which is mostly used with binding posts on amps,avrs,and speakers. I am an electrician with 25 years experience and when we need to splice or connect the 2 elements a special chemical must be used so to treat the 2 materials so that the connection will not get corroded when the conductors heat up under high amperage current is being delivered by them, so the speaker wire has the same charecteristics when 2 different materials are making contact and the banana plugs are treated with this chemical so the 2 different materials combine seamlessly, and this is a proven fact if you need more info look up the national electrical code for any state and you will find this info written in the manual. Lou
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    edited August 2005
    And like I stated before it also looks cooler and it makes it easier to make connections with no corrosion. :D
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    edited August 2005
    Bananas add another joint in the wiring and thats one that you just don't need. Why add more resistance? They are great if you find yourself disconnecting and reconnecting your speakers often. If your wire oxidizes enough in a years time to warrant trimming, then you might to start looking for some different wire. A simple dab of No-Ox or a drop of de-oxidizer is all that you need. Skip the extra connections and stick with nekkid wire.
    edited August 2005
    Exactly. That is what Ive always thought. All preference though.
    Testing
    Testing
    Testing
    edited August 2005
    Every high end cable comes terminated in some fashion, some of them allow you to change from spades to bananas or whatever. Bare wire is for amateurs. :D
    edited August 2005
    I guess because bare wire gets smooshed and oxidized over time and cutting back that expensive cable can start huring the wallet ;)
    edited August 2005
    Does it make a sonic difference?
    "God grooves with tubes."
    edited August 2005
    Do $5 cables sound worse than $100 cables?
    It's all subjective.
    edited August 2005
    Page 127: SMART HOMES FOR DUMMIES - 2003 2nd Edition
    Bare Wire, Pins, Banana Plugs, Spades
    "Any of the last three speaker-wire terminations is better than using bare wire ends. Which one you choose will probably be driven by the kinds of connections available on your amplifiers and speakers. You find the following connectors on typical amplifiers, speakers, and wall outlets."
    Spring-loaded clips, Banana-plug receptacles, Five-way binding posts.
    "When you purchase speaker outlets, do yourself a favor and skip any that have those spring-loaded, clip-style connections and go right for the banana or five-way binding post types."
    Anyone have any comments/opinions on what is quoted above from SMART HOMES FOR DUMMIES?
    edited August 2005
    unit731 wrote:
    Page 127:
    I agree with the above statement with regard to speaker wire connections on both speakers and receivers.
    Mains: polk R30
    Center: polk CSi3
    edited October 2005
    I'd say bare wire is the best way to go. Here's my reasoning: the terminals on your speakers and receiver are rigid as are banana plugs, to a lesser degree. They are going to connect cleanly, but also create low\no contact points. Bare wire is very pliable (especially common copper wire) and will bend and compress itself into the terminal as you tighten it, allowing for more surface area for contact to occur. I'm sure the difference is so small that it is virtually inaudible, but when one spends thousands on components, the ensuing neurosis makes sure all the little things are taken into account. For pure convenience however, I would recommend banana plugs. :)
    edited October 2005
    ^^ Good points. And I think I agree about the more surface area of contact with bare wires versus banana plugs. However, what about spades? Wouldn't they give you almost as much, if not as much, surface area of contact as bare wires? And they wouldn't oxidize and so wouldn't need to be trimmed back. And it'd be easier to change speakers/equipment than with bare wire.
    So, I think spades are the best solution. What do y'all say to that?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    edited October 2005
    Upon looking at a picture of some BFA banana plugs, I'll hafta admit that sure does look like a lot of contact area. However, it may not be very 'tight', thus increasing resistance. I'm not sure.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    edited October 2005
    to quote a good friend of mine...
    "poo nuggets..!!"
    adiobliss...those are good banana`s..
    I just like saying poo nuggets.. :D
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    edited October 2005
    I use them, it is very tight and secure. A tad on the pricy side, $25 for a set of four. Build quality is top notch, secured by two tiny screws to hold the wire and strands separately.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    edited October 2005
    Yes, they look like they'd do nicely. Makes me wonder...if they are soft enough to squish 'em flat with one hand they would have my full attention. When you think about it though, it's just another connection point to lose signal through. Are the screws gold plated too?
    edited October 2005
    honestly, I don't remember, and I am not about to go behind the amp to check 'em out (I have a rather difficult enclosed in-wall unit, which is also why banana is the ONLY practical way of connecting my speaker cables to the amp). Btw, why do you want to squeeze 'em flat? they are not soft, and there's no way you can flatten them with your bare hand.
    edited October 2005
    i prefer the BFA bayonet style banana plugs on the amplifier end and spades on the loudspeaker end. i am having a 10' pair of Groneberg TS premium loudspeaker cables built with this configuration. why ? because i can! does one have a distinct advantage over the other? i seriously doubt it and it is strictly a matter of preference....thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
    edited October 2005
    I suspect you are correct. I'm thinking that, when I get some other parts of my system 'up to snuff', I'll go with spades on both ends.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    edited October 2005
    Hehe......he said, "Poo nuggets"
    My take. There are good quality banana plugs and spades and there are bad quality. Pay the extra money for the good ones!!! The best joint on either is soldered, not screwed or crimped. If using bare wires, tin the ends.
Welcome!
Welcome!
