Sub hook up help
Pick
Pick Posts: 2
Hi,
I have the Polk RM6800 system........I received from Circuit City, with a free Onkyo TX-LR552 receiver. The Receiver has a hook up for the sub, that is a small outlet-looks to be stereo plug size, however the sub has no mate for it. The instructions said the prefered hook up for sub is on the speaker in connections, then hook front speakers to speaker out connections. With this set-up, I don't believe sub is putting out anything. Doing test of speakers, there is no clear sound just coming out of sub. Should I use a splitter stereo connector from receiver to Line In, red and white, or is the system indeed working ok? I really don't feel the Bass is coming through, as it's now wired.
Appreciate any help.
Thanks,
Pick
Post edited by Pick on
  • Mike682
    Mike682 Posts: 2,074
    edited August 2005
    First check that the receiver's sub speaker is turned on/enabled.
    Instead of using the speaker wire method, you can connect a sub cable from the receiver's sub pre-out to the line-in left connection on the sub. Also,if you want, you can use a Y-splitter to connect the receiver's sub-out to both the left/right line-in jacks at the same time.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • Pick
    Pick Posts: 2
    edited August 2005
    Thanks,
    I turned the subs volume all the way up and it's working..............if I think it'll need more, I'll go with the Y connection. I had to turn receivers sub setting off, as per manual.......but with volume on sub way up, I get good bass now.
    Pick
  • Mike682
    edited August 2005
    Pick wrote:
    Thanks,
    Pick
    The Y-splitter is supposed to give you an db increase in input so you don't have to turn the volume up all the way on the sub..
    Welcome to the forum... :D
    Mike
    Mains: polk R30
    Center: polk CSi3
  • vjvj
    vjvj Posts: 2
    edited August 2005
    Pick, Can I know How much you paid for the 6800 @ circuit city. I brought rm6750 at FRy's with Onkyo LR 552 rec for $499. I am planning to return and buy 6800 if the price is not too high.
  • Willow
    Willow Posts: 11,340
    edited August 2005
    You may wish to read the info on
    http://www.polkaudio.com/education/faq.php?article=hookupsub
    with a sub sat system your best bet is the speaker wire method
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2005
    Mike
    correct. but how many db's Mike? Is it 3db? 6db?
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Mike682
    edited August 2005
    I believe it's a 3db increase
    Mains: polk R30
    Center: polk CSi3
