bracing?box volume.
quanah
I am building a single ported enclosure for 8" db sub using (Polk's car audio sub plans) section for the specs its fairly detailed but doesnt say anything about internal bracing. So Im not sure if thats included in the .60 cu ft. --Thank you for any help
Post edited by quanah on
nope, any internal bracing you choose to add will change the internal volume, and you must change the box dimensions to compensate.
just be happy you're not doing a slot-port
could not imagine the box needing bracing that is that small with a polk 8" sub. Just build the box properly and you should be fine
Agreed.
A small box with only 200 watts isnt going to need bracing. Sure it cant hurt but unless youre running 1/8 inch wood, I cant imagine it flexing.
Now if you are building a much bigger box with lots of straight, flat pieces and using a lot or power, then youd need some support.polkaudio sound quality competitor since 2005
Thanks for reply.
i'm dumping something like 2,000 watts into box around 2 cubic feet with no bracing other than a divider wall.
I used to pump 1,300 into boxes that were 1.43 cubes with no bracing.
just build a healthy box dude. 3/4 inch birch ply is PIMP stuff.The Artist formerly known as PoweredByDodge -
Birch plywood is all Ill ever use from now on.
I just built one out of 1/2" birch ply and its as strong as my previous box made with 3/4" MDF. More expensive but worth it.polkaudio sound quality competitor since 2005
its easier to work with too. you can actually FILE the stuff - lol.The Artist formerly known as PoweredByDodge
Another benefit is that since its stronger you can use thinner than usual and thatll give you more interior volume that takes up less space in case youve got tiny little areas for subs like my truck. Definitley wasnt designed by a car stereo enthusiast.polkaudio sound quality competitor since 2005
