Subwoofer for Rti4
Can i use the PSW12 sub [Monitor series] with Rti4 speakers?
How do u rate this sub?
You can use any sub with your speakers regardless of brand, etc...
I never heard the PSW12, so I can't comment on how it sounds.
Best bet would be to take a run to the dealer and give the PSW12 a listen...then compare it to other subs, then pick the best one in your budget...Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
