tweeters and power
Systems
Systems Posts: 14,873
edited June 2002 in Car Audio & Electronics
First off i have a question about tweeters.....
i have a pair of DX components of front and a pair in the back. yesterday it was raining really hard and i forgot to roll up my window!!!(i know im stupid!) and the tweeter got all wet! and i was wondering how this can hurt my woofer and tweeter? and how can i tell if the tweeter is wrecked? and woofer?
ANOTHER question i have is with power.......
right now i can get about 11.8 volts to my amp, how is the best way to get 14.4 volts?! would a capacitor do it? thanks for your help!!
Testing
Testing
Testing
  • MikeVB
    MikeVB Posts: 16
    edited June 2002
    You should be getting the 14 volts when the engine is running because of the alternator's output, and about 12 volts when the motor is off.
    Mike
