SVS owners + Hardwood floors...
VR3
How do you guys do it?
I had my SVS on a hardwood floor for about 5 hours the other week...
You wont believe how many times I had to move that thing back to where I had it 10 minutes before...
That thing, a lil 550 dollar sub... was walking across the room. Those lil rubber feet do NOT work.
How can yall take it? lol
I place everything I own in a certain spot...if it constantly moved..Id go bonkers!
Post edited by VR3 on
Can you say O.C.D.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Sid, you must have been crankin' it! If you're that worried about something moving, you need to get out more..LOL. No offence guy, I'm the same way, everything has to be in it's place.Larry
Thing was bouncing around.
No, I just spend alot of time in my room listening to music, and my stereo is setup for precision. My mains are the same exact distance from the side walls and back walls on one corner. Different toe in angles though.
I just like things -right.-
I hate dust to.
But seriously, that SVS...I was sitting about 2 feet away, and every 10 minutes or so...I would feel this "bump" at my leg...lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
so your SVS was humping your leg? Or was it the other way around?Originally posted by Vr3MxStyler2k3
gmorris had to put a piece of carpet under his monster sonosub to keep it from walking on his tile floor.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Your good with wood: build a tie down plate- Put 2 25lb weights mounted on a crossbrace through the gap between the speaker and the base. If the SVS can move it's own weight plus 50lbs, it deserves to go wherever it wants.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
HAHA..... even out to dinner maybe? -
buy one of those rubber mats you see in gyms. They stick to the floor like glue. BTW, you should probably spend a little more time in the gym. At your age muscles, not SVS' get chicks.
Sid can get muscles with SVS by lifting it whenever it get moved from its position
-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
I'm a bit worried because we are getting hardwood floors in the next year or so and mines downfiring with casters.... time for a giant area rug.
Sid,
Let Ron (rons@svsubwoofers.com) at SVS know the problem you are having. I seem to recall that other owners with hardwood floors have had the same problem and SVS was able to help them. -
I've had some of the wifes dainty crystal stuff moving on a table next to it and on the fireplace mantle, but can't really say the PB12-Plus has moved at all on the hardwood floor. I'll have to put some chalk lines down for reference. I didn't install the rubber feet that came in the bag. It just sits on the rubber feet that are attached to the legs.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Nah, I have a carpeted floor.
Was just asking a general questions how owners delt with this...as it would drive me crazy.
I would -hope- your box sub hasnt moved. Those things are HEAVY. My SVS only weighs 60 pounds (CYLINDERS RULE!
) - Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
As far as the box subs moving around,i have a svspb2+ that i recently had on a marble stand that had 1 inch carpet spikes glued to the bottom of it.I had to remove the sub from it because it would rattle the the spikes on the concrete even though it was still going through some really thick carpeting and padding.*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
thatseems to suck. my box sub never moved but it was 4 ft by 4 ft by 2 but my new sub will move the wall and it is over 200lbs
jdhdiggs wrote:If the SVS can move it's own weight plus 50lbs, it deserves to go wherever it wants.
AMEN!
