SVS owners + Hardwood floors...
VR3
VR3 Posts: 29,549
How do you guys do it?
I had my SVS on a hardwood floor for about 5 hours the other week...
You wont believe how many times I had to move that thing back to where I had it 10 minutes before...
That thing, a lil 550 dollar sub... was walking across the room. Those lil rubber feet do NOT work.
How can yall take it? lol
I place everything I own in a certain spot...if it constantly moved..Id go bonkers!
Post edited by VR3 on
  • Skynut
    Skynut Posts: 2,967
    edited July 2005
    Can you say O.C.D. :D
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • maggiefan
    maggiefan Posts: 223
    edited July 2005
    Sid, you must have been crankin' it! If you're that worried about something moving, you need to get out more..LOL. No offence guy, I'm the same way, everything has to be in it's place.
    Larry
    VR3 Posts: 29,549
    edited July 2005
    Thing was bouncing around.
    No, I just spend alot of time in my room listening to music, and my stereo is setup for precision. My mains are the same exact distance from the side walls and back walls on one corner. Different toe in angles though.
    I just like things -right.-
    I hate dust to.
    But seriously, that SVS...I was sitting about 2 feet away, and every 10 minutes or so...I would feel this "bump" at my leg...lol
  • tryrrthg
    tryrrthg Posts: 1,896
    edited July 2005
    so your SVS was humping your leg? Or was it the other way around? :D
    gmorris had to put a piece of carpet under his monster sonosub to keep it from walking on his tile floor.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited July 2005
    Your good with wood: build a tie down plate- Put 2 25lb weights mounted on a crossbrace through the gap between the speaker and the base. If the SVS can move it's own weight plus 50lbs, it deserves to go wherever it wants.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • BrentMcGhee
    BrentMcGhee Posts: 548
    edited July 2005
    HAHA..... even out to dinner maybe?
  • wallstreet
    wallstreet Posts: 1,405
    edited July 2005
    buy one of those rubber mats you see in gyms. They stick to the floor like glue. BTW, you should probably spend a little more time in the gym. At your age muscles, not SVS' get chicks.
  • izafar
    izafar Posts: 820
    edited July 2005
    Sid can get muscles with SVS by lifting it whenever it get moved from its position :D
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • michael_w
    michael_w Posts: 2,813
    edited July 2005
    I'm a bit worried because we are getting hardwood floors in the next year or so and mines downfiring with casters.... time for a giant area rug.
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited July 2005
    Sid,
    Let Ron (rons@svsubwoofers.com) at SVS know the problem you are having. I seem to recall that other owners with hardwood floors have had the same problem and SVS was able to help them.
    SCompRacer Posts: 9,122
    edited July 2005
    I've had some of the wifes dainty crystal stuff moving on a table next to it and on the fireplace mantle, but can't really say the PB12-Plus has moved at all on the hardwood floor. I'll have to put some chalk lines down for reference. I didn't install the rubber feet that came in the bag. It just sits on the rubber feet that are attached to the legs.
    VR3 Posts: 29,549
    edited July 2005
    Nah, I have a carpeted floor.
    Was just asking a general questions how owners delt with this...as it would drive me crazy.
    I would -hope- your box sub hasnt moved. Those things are HEAVY. My SVS only weighs 60 pounds (CYLINDERS RULE! ;))
  • racer4551
    racer4551 Posts: 373
    edited July 2005
    As far as the box subs moving around,i have a svspb2+ that i recently had on a marble stand that had 1 inch carpet spikes glued to the bottom of it.I had to remove the sub from it because it would rattle the the spikes on the concrete even though it was still going through some really thick carpeting and padding.
    *HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
  • goingganzo
    goingganzo Posts: 2,793
    edited July 2005
    thatseems to suck. my box sub never moved but it was 4 ft by 4 ft by 2 but my new sub will move the wall and it is over 200lbs
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited July 2005
    AMEN! :p
