How much for PSW 404/505
ode
Looking for a powered sub, I was wondering what good prices are for the psw 404 and 505, if they ever go on an outrageous special at Frys or any other place like the R50s do and what older models to look for that will be a match to the 404 and 505. I have 4 R50s and a CS1 may as well go for the polk sub to match. Thank you.
Post edited by ode on
Sub matching is not as important as matching other speaks. So when sub shopping, you can look at other brands if they fit your budget...
I would say for the 404, a very, very good price for a brand new, sealed box from an authorized dealer would be around $279-$299......used ones have gone for around $175 plus shipping here.....not sure about the 505 though.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
go for velodyne,svs or some of the hsu research subs which are a bit better than the polk subs, unless you can find something like a psw 650 from polk now that was a sub.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
