can you use a Y splitter from the dodd to mono amp?
faster100
faster100 Posts: 6,124
edited July 2005 in 2 Channel Audio
Just like the title says.. can i use a Y splitter from the dodd's left/right out to a single rca cable to the mono in on the amp? just playing around and want to increase the input to the amp
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • unc2701
    unc2701 Posts: 3,587
    edited July 2005
    No!!!
    You need to get a special box to combine the signals. I'll try to find an ebay link.
    Backburner:Krell KAV-300i
  • faster100
    edited July 2005
    your kidding right? LOL
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • nadams
    nadams Posts: 5,877
    edited July 2005
    You ask a question then don't believe the answer?
    Ludicrous gibs!
  • faster100
    edited July 2005
    did you see the LOL? obviously because i did it and it worked but am afraid after i seen his response... what will it do? UNC has helped me before and i believe him... was just like, your kidding right, opps i did it already type response... calm down there :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited July 2005
    Yes you can do it. People do it all the time to combine L&R signals for subwoofers with a mono input.
  • faster100
    edited July 2005
    That was why i did do it, thought the same thing... didnt do anything when i tried it but work.. Thanks
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • unc2701
    edited July 2005
    Russman-
    You sure about that? I thought they had to go through isolation transformers in order to keep from **** up your pre-amp... Unless it's different SS vs tubes?
    edit: I'm not saying it won't work, but the crossing signals would present a weird load for the preamp- I know for some pro-sound things I've done, we feed L-R signals into a combiner box, but you can ghetto rig one w/ a pair of 1:1 transformers.
