can you use a Y splitter from the dodd to mono amp?
faster100
Just like the title says.. can i use a Y splitter from the dodd's left/right out to a single rca cable to the mono in on the amp? just playing around and want to increase the input to the amp
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
No!!!
You need to get a special box to combine the signals. I'll try to find an ebay link.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
your kidding right? LOLMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
You ask a question then don't believe the answer?Ludicrous gibs!
did you see the LOL? obviously because i did it and it worked but am afraid after i seen his response... what will it do? UNC has helped me before and i believe him... was just like, your kidding right, opps i did it already type response... calm down thereMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Yes you can do it. People do it all the time to combine L&R signals for subwoofers with a mono input.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
That was why i did do it, thought the same thing... didnt do anything when i tried it but work.. ThanksMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Russman-
You sure about that? I thought they had to go through isolation transformers in order to keep from **** up your pre-amp... Unless it's different SS vs tubes?
edit: I'm not saying it won't work, but the crossing signals would present a weird load for the preamp- I know for some pro-sound things I've done, we feed L-R signals into a combiner box, but you can ghetto rig one w/ a pair of 1:1 transformers.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
