Polk Sub Box
Systems
Systems Posts: 14,872
edited July 2005 in Car Subwoofer Talk
Hello everybody!!!
Can you guys give me an idea of the size of a sealed box for my Polk Dx 12" (4 Ohm) if I use a 125 RMS amp...
I can't get any bigger amp, no money for that. I'm currently using a 0.77cu ft box but is too small...
Thanks in advance for the input
Testing
Testing
Testing
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2005
    The sealed box volume should be .88 cubic feet.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited July 2005
    id make the box about 1.2 ft^3 unless youre planning on getting a bigger amp soon, then id build it to .88 that way you wont have to make another one
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2005
    Actually the spec is .85 ft^3.
    -Cody
    Isnt that a little too big? I know he's underpowering it but thats nearly 50% bigger.
  • exalted512
    edited July 2005
    http://polkaudio.com/car/specs.php?name=dx12-8
    it says .88
    i dont think the box is too big. hes playing it a nearly a quarter of its rated power
    -Cody
  • MacLeod
    edited July 2005
    http://www.polkaudio.com/car/toolbox/subboxplans/subbox_plan.php?id=9&mesurements=standard
    Thats weird. There it has .85 ft^3.
    Doesnt matter tho, .3 aint enough to worry about.
    1/4 its rated power? Good grief. If thats the case you should really look to getting a bigger amp. Youre missing out on a lot.
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2005
    it's .03, and the .88 shows up more often than the .5, so i'd have to guess that that's the right answer.
    and yeah, a bigger amp is definitely in order...
