LSIFX dilemma
wingnut4772
Okay...I finally decided on LCI80is for my back surrounds (in ceiling speakers)....Now I need to decide whether or not I can place my LSIFXs (side surrounds) up high at a 45 degree angle pointing at the sweet spot (where my new ceiling will meet the walls at about an 8 foot height). I don't want to do the in wall Polk surrounds as I do not feel they will sound as good as the LSIFXs. Also, one wall is solid concrete block.
Since my rear surrounds will be in the ceiling....this should work , right? I mean that's the way movie theaters do it. I can't put them lower because my room is so narrow that anyone that walks by them is in danger of bumping them off the walls --AND I have a window in the way on the left. Any input would be very welcome. TIA
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
Dipoles are so diffuse by design that you don't really need to angle them down. Place them high enough to avoid people, and you should be good.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Hmmmm..really? Not even little angle? It just seems like all that sound will be floating up there in the ceiling and I will be like, "Hey! I'm down here!".
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I've used dipoles as "sides" for the last couple HT setups, and if you actually are placing them with the tops at the 8 foot ceiling, I would angle them down. This will help to minimize the reflection from the ceiling too. Placement high on the wall is the best for side mounted dipoles since this allows the sound to get to all people in the room without going through those sitting next to us. Anything above ear level is good.
When you hear dipoles in use you really can't place where they are at, since they are made to sound this way, and placement isn't as critical as a single plane (standard) speaker requires.
How far are your rears going to be from your seats? Do those models have adjustable tweeter mounts?HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks Dennis. The rear speakers will be about 4 to 5 feet back in the ceiling (about 8 ft). The tweeters can be aimed . The room is only 12 feet wide so ...at about 8 feet high, how much would you say to angle the Fx's?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
30 to 45 degrees should be okay.
Try placing them slightly behind your primary seating if you can. I have had mine in front, beside and behind my first seats and prefer them slightly behind the seats. It just seems to work best with the fronts this way. Putting them in front of the seating was the worst, as surround effects didn't pan from front to back properly. Too much frontal weight.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
They are going to be directly to the sides. I may be able to push the sofa farther forward to achieve the same thing...A foot or so mebbe. This room is very limiting....but I will make it work! As God as my witness...ya da ya da ya da and so forth.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
