Onkyo M-282 amplifier question
landry_p2000
Will the Onkyo M-282 hook up to my Onkyo TX-SR601, and allow me to run my RTi10 fronts from the amp, and the other speakers through the TX-SR601? I want to add this to send more power to my fronts. Any help would be appreciated.
Thanks,
Landry
Thanks,
Landry
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
Post edited by landry_p2000 on
I used the center channel pre-out on my rcvr with a y adapter and sent the center signal into my m282, from there it powers the L&R rt55's on each side of my t.v.
Works good for me.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks for the reply Synut. I have been thinking about getting this unit for my fronts. Do you think it will make a noticeable difference for music in 2-channel stereo mode?Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
My 787 is rated @ 100 wpc and so is the amp so I did not notice any more clarity or power, however I am only using it as additional power for the center so it did improve the soundstage.
If it has more power than your rcvr then you will probably notice a difference.
Personally I like the amp for the cost I paid.
Vanns m 282Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Wow, all this discussion and the most important part is being missed
Does your receiver have preamp outputs? That's the question you need to answer before anything else.
I could be wrong (but I'm not), but I don't think your receiver has preamp outputs...meaning you'd have no way to hook up another amp to that receiver. -
I saw this amp on Circuitcity.com, but I would save buying it from Vann's. Thanks a million.:)Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Make sure you read my post above before buying anything. Your 601 does not have preamp outputs, you won't be able to use this amp with your current setup.Originally posted by landry_p2000
I saw this amp on Circuitcity.com, but I would save buying it from Vann's. Thanks a million.:) -
That would suck.
If you buy the amp and then need a new rcvr to play with it.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Aww damn! It doesn't have the preamp outputs. Thanks Polkmaniac. Thats why I asked you guys to be sure.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Just to help illustrate
Here's a diagram of the back of yours... -
and here's the 787 that skynut has...section 4 is the preamp section that you're missing...
How about a Y splitter from the sub out for the amp hook-up, and run the sub from the front left and right? Be patient with me PM, just trying to learn as much as possible.:DMain Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Nope, I wouldn't suggest that. If you're looking for an upgrade in sound on the front end, I'd look at first upgrading to a receiver with preamp outputs. By the time you sell yours and buy another one, you should be able to make this move for fairly cheap, less than what you were going to pay for the Outlaw amp.Originally posted by landry_p2000
Then if you can get the amp, pick it up. If not, save a bit longer and buy it when you can. -
Thanks PM. You got me on the level. I appreciate you guys putting up with with me and my novice questions.:rolleyes:Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
NP, I've asked plenty of questions here myself...Originally posted by landry_p2000
Thanks PM. You got me on the level. I appreciate you guys putting up with with me and my novice questions.:rolleyes: -
unless you just want to give your 10's more bass, not recommended. That preout is purely bass, not a shred above 80-100htz.Originally posted by landry_p2000
How about a Y splitter from the sub out for the amp hook-up, and run the sub from the front left and right? Be patient with me PM, just trying to learn as much as possible.:DNever kick a fresh **** on a hot day.
