CSi3 - Inverted Height
What is the height of the CSi3 when it is inverted to face upward? I would also like to know if anyone has an opinion on using this speaker with a pair of front Klipsch KG3's.
Post edited by wdsnls on
Hi Wdsnls. Welcome to the forums.
On a vertical plane the Csi-3 would measure 20"H x 6-7/8"W x 9-1/4"D.
As far as using it with Klipsch KG3's (or any Klipsch for that matter) you're going to get a night and day sound. You can forget about proper timbre. If you already have Klipsch front stereo speakers, I recommend you go ahead and finish it out with a Klipsch center. If you haven't bought anything yet, then I recommend the CSI-3 as well as any of the speakers in the RTI-line to pair with it.
The sound characteristics of Polks and Klipsch are totally different- and imo I don't think you're going to find many people on these forums that prefer the bright, steely sound of Klipsch horn tweeters- over the more neutral, laidback sound of the Polk RTI and LSI line; myself included.
Hope this helps: and again- welcome to the forums.
