delema
phlinnie
My monitor 30's fronts and csi5 center are biwired should I set them to large and set the base management to both to include my powered sub. I'm in the middle of wiring so someone please help a beginner.
Post edited by phlinnie on
I'm not quite sure what kind of bass management you're talking about but I would think you would want to set both the center and the monitor 30s to small and let the subwoofer handle the lower frequencies. You can play around with large/small and the crossover to see what sounds best to you but it would take a load off your receiver / amplifier to set them to small.
No, set them to small and cross your sub over to 80 Hz or higher.
Yup, what amulford said..absolutely.suds, suds and more suds!
