? on replacing sl2000 in sda-1
OldSycamoreTree
The speaker cabinet has white and black wire leads.
the new silk dome tweets have a plain spade terminal and one colored red.
Just verifying that the white wire goes on the red spade.
black wire onto plain spade.
btw, what are those crazy fasteners holding the tweeters into the cabinet? Luckily I have a screw driver that works and does not strip them.
Post edited by OldSycamoreTree on
No, that's incorrect. Polk has a backwards way of wiring speakers. Black is positive (goes to the red terminal), white is negative.Political Correctness'.........defined
President of Club Polk -
that's why I asked the board.
I never would have thought of black as positive.
isn't there a rule in electronics that black is negative? -
Generally yes, but the Polk guys were smoking the peace pipe a little too much back then.Political Correctness'.........defined
so if I had pulled that one first it would have baffled me just the same.
good thing they were not making bombs that a bomb squad tech would have to disarm someday.
one speaker done, one to go then get to try them out. -
can't get the tweeters out in the right speaker with my oddball screwdriver.
is the tool I need called a torx?
guess I will be listening to silk and silver tonight:( -
Right, black or blue are positive. White or green are negative. Which screws are you removing? You should be removing the four screws at the far corners, not the ones closest to the actual dome.Political Correctness'.........defined
but the heads are inset with a nearly square shape, having a sort of flare- out at the corners.
they are not normal philips head screws, nor are they hex shaped. -
Hmmm....sounds like somebody used sheet rock screws. Get rid of those and buy some oval or pan heads. These guys have some, http://www.madisound.com/accessories.htmlPolitical Correctness'.........defined
what tool is used to remove the screws on those SL2000's? When I go to Home Depot. i want to make sure i get the right one..PolkFest 2012, who's going>?
IIRC, there are two sizes of square drive screw heads so measure them before you go to buy. Some of the drill driven drivers have a different size tip on each end.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
i checked the other drivers and they all have this odd fastener securing them. Wish they were normal screws like everyone else uses. I tried 2 sizes of philips but ng and don't want to strip these things.
the tweeters i removed were original I'm certain, and dated 1992 on back with QC cert. -
There are actually a few sizes of square drive, but two sizes are the most common.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Look, this isn't that complicated. The screw holes strip easily, so someone at some point replaced the original screws with what you have now, probably a size or two larger than original. Polk never used a screw like you're describing. Take one of them to a hardware store tomorrow, match it up with the right tool and be done with it.
BTW, the SDA 1's were made from '82 to '83, the 1A's from '83 to '86, so obviously the tweeters have been replaced.Political Correctness'.........defined
all the fasteners have this square head design. It seems odd that someone before me would replace all the drivers and then put in these square drive screws. I know its not complicated but unusual to say the least.
I have replaced woofs and tweets in other brands before and have never seen this screw.
The speakers were bought second hand and seller just knew they were his relative's and he was an "audio nut."
from seaching other threads I think I have the sda-1c studio.
Sometimes I read something that refutes this, such as the "1c did not have the spade/ spade interconnect"
My right speaker is s/n 5142 ; the left has no id label.
They are black, but do not have the top cap which other's photos of1c's show.
__________________________________________________
danger boy- have you looked at your fasteners? they may not be like the ones I encountered here. -
Well... someone is wrong, there were some 1Cs made with the blade\blade connections. Fact not fiction.
