FT Audio LW1 passive preamp
Aaron
Aaron Posts: 1,853
edited June 2002 in 2 Channel Audio
For those of you with an interest in passive preamps (umm, that's you BDT), check out this review. Pretty interesting piece.
FT Audio LW1 Passive Preamplifier
Aaron
Post edited by Aaron on
  • juice21
    juice21 Posts: 1,866
    edited June 2002
    don't you have some demoing to go out and do? since you don't have a job and all yet? :D
  • Aaron
    Aaron Posts: 1,853
    edited June 2002
    Hahah. I really doubt it would be worth my time until I get new speakers. Then I can try to find a matching amp/preamp combo. I think that's going to be a big pain in the butt, but I'm sure I'll have lots 'o fun.
    Aaron
  • TroyD
    TroyD Posts: 13,124
    edited June 2002
    cool review......like I said, if your needs are simple, a passive is a great option.
    BDT
  • TroyD
    TroyD Posts: 13,124
    edited June 2002
    One point, not that anyone but myself and maybe Russ cares, that was brought out in the review and something I've been listening for the last few hrs in the man cave is the quality of the recordings. What is on the disc is what you get, no more, no less...
    I've got a few cd's that were downloaded off the internet as well as some cd's that were poorly recorded (Eric Clapton).....a passive pre will do nothing for them. A solid case is a copy of the Cult's "Fire Woman". I've got the orginal cd and it is great but the burned copy I have is damn near unlistenable on the mancave rig...
    Just thought I'd share...
    Troy
  • Aaron
    Aaron Posts: 1,853
    edited June 2002
    no more, no less...
    OK, Yoda. :D
    Aaron
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2002
    My only beef is that if you have in-effcient speaks, and possibly a low(er) voltage source, you may not get the juice you want....
    But as far as audio purity, and non-coloration, you gotta (mantis, this one's for you) test it at the minimum, to see if it floats your boat....
    Cheers,
    Russ
