Fuse For 5jrs
rebfan
I've got a pair of 5jrs with blown fuses. Does anyone know what type of fuse goes in the 5jrs?
Post edited by rebfan on
Read the info on the fuse caps.Political Correctness'.........defined
President of Club Polk -
I believe they use a 5 fast burn."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
1 amp fast blowCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Originally posted by RuSsMaN
1 amp fast blow
See, there's your answer.
BTW, what should the 10A's have?"SOME PEOPLE CALL ME MAURICE,
The info on the fuses is unreadable. Where would I get these fuses?
Rat Shack"SOME PEOPLE CALL ME MAURICE,
i just picked up a pair of monitor 7's, and one of them is lacking both the fuse and the fuse holder. both are playing, with no apparent problems (all the drivers are firing, and sound great). do i need to do something, or can i go without a fuse? if i do need a fuse, how would i go about attaching a new holder?
thanks,
andrew -
Not all old monitors have fuses. They eventually switched over to an internal circuit breaker-type design.Ludicrous gibs!
my pair of speakers appear to be an original matched pair, so i had assumed that the fuse assembly had been broken off of one of them. how do i check if the speaker i have should have the assembly, or has an internal setup like mentioned?
Well, without the fuse present (if it's truley broken off), you'll get no sound out of the tweeter on that speaker. That would be the easiest way to tell. Unless the previous owner somehow bypassed the fuse terminals and just has it straight wired.Ludicrous gibs!
