Mix and Matching
phlinnie
phlinnie Posts: 8
I have A polk csi5 center channel and 2 polk monitor 30 fronts. Could I use any of the polk sattelite speakers for this combination for a 7.1 system.
Post edited by phlinnie on
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    buy some rti6's for the front- and put your monitor 30's in the back.
    THe front 3 should be timbrematched. The surrounds not necessarily.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Willow
    Willow Posts: 11,231
    edited June 2005
    you could however you will not get a seamless sound. I found a big diff went I bought my rti8's and moved my rti4 to the rears. Big diff. But if $$ is an issue you will do fine.
  • Early B.
    Early B. Posts: 7,900
    edited June 2005
    You first need to determine if a 7.1 system is what you need. Gotta have plenty for it to be worthwhile. A 5.1 system is best for most home applications.
    You're off to a good start with your center channel. Buy the best speakers you can afford and don't worry about timbre matching for the rear/surrounds.
    "God grooves with tubes."
