diy sonotube
tecmo04
so all this talk about diy subs has realy inspired me to try one myself. unfortunatly i know absolutly nothing about this process. all i know is that i wnat to try and build a beast that can change my heart beat and shake my teeth out. so here are a few questions to get me started...
1-id like to build a sonotube so where do io buy the tube?
12" or 15"?
height?
plate amp or seperate?
size and leigth of ports?
cost?
hrs and difficulty of construction?
yada yada yada ...
any help and advise would be GREATLY appreciated.
12" or 15"?
height?
cost?
yada yada yada ...
Post edited by tecmo04 on
Let a little google in your life
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
im trying to get some expert input, hense asking the pros...
Try your local concrete supply company, the local Home Depot and Lowe don't have the big enough tubes (not in my area anyway) Also, sonotube is a brand name, but any of the concrete form tubes will doOriginally posted by tecmo04
No pro here, but
Not sure if you asking about the tube size or the subwoofer driver size, but for heart beat changing teeth rattling, I would go 15" driverOriginally posted by tecmo04
12" or 15"?
You gotta pick a driver firstOriginally posted by tecmo04
height?
you choice, plate amp has many features not on a separtae amp, crossover, phase adjustment and suchOriginally posted by tecmo04
depends on your driver and amp selction, but it is easy to get a great sub for around 500.00(150 driver, 200 amp, 80 for the tube, 30 or so of wood (MDF) screws and glue, 50 for the finish)Originally posted by tecmo04
cost?
hard to say how long it will take you to make it, plan on 10-20 hours and it is not hard at allOriginally posted by tecmo04
hrs and difficulty of constructionDodd - Battery Preamp
Yeah, what he said.
Since all the Ascendant drivers are probably gone, I would suggest getting one of the new AV12 or AV15 drivers from (former Stryke Audio). They are monster woofers.
LINKSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
my .02, go plate amp. ive tried both routes and plate amps always worked better for me. Maybe its what they were designed to do, i dont know. but i get much better performance in my DIY subs from a plate amp.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
download a program called unibox ... its actually an excel worlcsheet with macros. You will need the specs of the driver first.
I would probably go plate amp because it already has features lilce crossover and phase. -
My DIY Sonosub is a 24"x36" tube with 2-3"x17" flared port kits and a bit of batting wrapped around the inside of the sonotube. It has a single 15" Tempest driver and is powered by a 250w plate amp from Partexpress.If...
Ron loves a film = don't even rent. -
or try a program called winIsd... both have their advantages over each other but if you dont have ms excel use winIsd.
